Page 1 of 2
Re: Lua Script for turning light on when motion
Posted: Friday 26 December 2014 18:39
by leby
Hej, change 'Set Level 100' to 'On' then it should work. Is it a dimmer or an on/off switch?
if (devicechanged['Badrum-Motion'] == 'Motion' and otherdevices['Badrum-Belysning'] == 'Off') then
commandArray['Badrum-Belysning']='On'
print('Badrum-Belysning on!')
Posted: Friday 26 December 2014 20:36
by Chopper_Rob
The reason that the print command does work is that it is outside of the if statement. So every time the script runs it will always log to the event log. Put the print command before the end statement to make it dependent of the if statement.
Posted: Friday 26 December 2014 21:35
by leby
Sorry, didnt see first time, a motion sensor is normally indicated as "On" not as "Motion"
if (devicechanged['Badrum-Motion'] == 'On' and otherdevices['Badrum-Belysning'] == 'Off') then
End
or
if (devicechanged['Badrum-Motion'] and otherdevices['Badrum-Belysning'] == 'Off') then
End
which motion sensor do you have?
Posted: Saturday 27 December 2014 9:13
by pvm
Wouldn't it be easier to use blocky events to do this?
Posted: Saturday 27 December 2014 10:17
by leby
Blockly would definitely be easier but perhaps not so fun
The problem with your script now is that you want the time to be more than 23 and less than 8, a bit tricky I would say if you start to think about it
If you change the 'and' to 'or' you would cover the time period you intend. You want the time to be 23,24, or 1,2,3,4,5,6,7,8
I have not tested the code below but I think it should work, If you want to use time in your lua script I suggest you spend a few minutes looking in to this site
http://www.lua.org/pil/22.1.html
hour = (os.date('%H'))
if (devicechanged['Badrum-Motion'] == 'On' and (hour >= 23 or hour < 8) and otherdevices['Badrum-Belysning'] == 'Off') then
commandArray['Badrum-Belysning']='Set Level 50'
print("Badrum Belysning on 50%")
commandArray['Badrum-Belysning']='Set Level 100'
print('Badrum Belysning on 100%')
Posted: Saturday 27 December 2014 10:46
by pvm
Agree Leby,
The script you provide is missing something, the else will work for all checks provided. I think you need need an if for the switches and within the then statement another if with checks on time
Posted: Saturday 27 December 2014 11:14
by simonrg
Posted: Sunday 28 December 2014 15:42
by leby
As simonrg say, the smart pir might be better but, if you want to do what you wrote in the first post you could do like the code below, I have tested it with a dummy device and its working as you intended with the twist that it turns off the light after 5 minutes, you can take that code part out if you wish to turn off manually.
-- the script turns on the dimmer for 5 minutes, the level during daytime is 100 and night 50
h = tonumber((os.date('%H')))
if (h >= 8 and h < 23) then
x = 'Set Level 100 FOR 5'
x = 'Set Level 50 FOR 5'
commandArray['Badrum-Belysning']= x
print(x)
Posted: Tuesday 11 August 2015 16:05
by cpighin
I'm going to insert my issue into this topic instead of creating a new one
As a first step for learing LUA funcionality I would light a lamp connected to a FibaroSwitch (Switch1) when my Fibaro Motion Sensor (OcchioMagicoFibaro-PIR) detects a movement.
I have created a simple lua file
script_device_LightOnAfterMovement.lua
print('this will end up in the domoticz log')
if (devicechanged['OcchioMagicoFibaro-PIR'] == 'On' then
commandArray['Switch1']='On'
and the lamp does not light when moving in front of the MotionSensor.
Where am I wrong?
Claudio
Posted: Tuesday 11 August 2015 19:58
by simonrg
Where am I wrong?
Claudio
You are missing a closing bracket on your if line:
if (devicechanged['OcchioMagicoFibaro-PIR'] == 'On') then
print('Motion detected')
Posted: Tuesday 11 August 2015 21:23
by cpighin
Where am I wrong?
Claudio
I corrected my error and tested the file which now works quite fine lighting the lamp.
I note that the action is not immediate and some times the Switch1 goes on status On after tens of seconds or doesen't act at all. Is this normal?
Claudio
Posted: Thursday 20 August 2015 19:03
by cpighin
I have done few test and realized that the
LUA script works always fine (the lamp light on if a movement is detected) only if
- Dashboard shows both devices OcchioMagicoFibaro-PIR and Switch1 in the state: Off
- a movement is perceived by the Motion Sensor (OcchioMagicoFibaro-PIR)
If OcchioMagicoFibaro-PIR is in status On (with Switch1 in status On or Off), the system doesn't reacts.
I believe this is exactly what is expected Domoticz does. If not, please advice me
I observed also that the status of my
OcchioMagicoFibaro-PIR changes automatically from On to Off after 30 sec. if no further movement is detected (I guess this parameter can be changed in the configuration file).
After learning how to use a LUA script ,
I would like to improve it to ensure that the lamp comes on when the sensor detects motion and stays on unless no movements are detected for 2 minutes.
Can you help me?
Claudio
Posted: Thursday 20 August 2015 20:32
by simonrg
cpighin wrote:After learning how to use a LUA script , I would like to improve it to ensure that the lamp comes on when the sensor detects motion and stays on unless no movements are detected for 2 minutes.
Not wishing to repeat myself, but you now seem to be trying to do exactly what the Smart Lua Scripts were designed for so have a look at
http://www.domoticz.com/wiki/Smart_Lua_ ... _Smart_PIR, basically will keep a light on for a defined length of time after last motion detection and can be configured by the way you name the PIR in Domoticz.
Posted: Thursday 20 August 2015 21:17
by pvm
You can also use setting 6 in your fibaro 'eye', no need for lua (though it is nice to learn something new
Posted: Friday 21 August 2015 12:58
by cpighin
simonrg wrote:Not wishing to repeat myself, but you now seem to be trying to do exactly what the Smart Lua Scripts were designed for so have a look at
Tanks simong
I was tryong to follow yor suggestion and I encountered the first obstacle on undesrstanding what exactly to do.
In the link mentioned I read
Adding Turning Off Functionality[edit]
First in Domoticz add a new Siemens PIR and call it after a light in your house, say the "Study" light, so the PIR is named "PIRStudy", make its device type "Motion Sensor". Then add the scripts described below.
Should I understand to create a new "virtual" device (if so please instruct me on haw to) or Should I rename my actual device "OcchioMagicoFibaro-PIR" in "PIR-OcchioMagicoFibaro" (or something else)?
Claudio
Posted: Friday 21 August 2015 13:29
by simonrg
cpighin wrote:Adding Turning Off Functionality[edit]
You are going to rename your actual device, the idea is that then the script will know that this is a PIR just from its name and so will pick up any PIRs not just a single 1.
Further down the wiki page the idea is to add some parameters that allow you to set how long the PIR stays on for, whether it comes on only at night etc..
Of course the reason why I wrote the scripts was that I have some very simple PIRs which only say I've seen something and don't even turn off ever, it sounds like your PIR could do a lot of this itself, but it still may be nice to be able to set them from Domoticz rather than on the hardware.
Posted: Friday 21 August 2015 14:57
by cpighin
Thanks simonrg
Since i would prefer to avoid the renaming of devices, is it possible to modify your script
-- ~/domoticz/scripts/lua/script_device_PIRs.lua
tc=next(devicechanged)
v=tostring(tc)
if (v:sub(1,3) == 'PIR') then
c=v:sub(4)
commandArray[c] = 'On'
tmess = c..' On - time 0'
print(tmess)
in order to consider only a device with a specific name (for example OcchioMagicoFibaro-PIR)?
Claudio
Posted: Friday 21 August 2015 15:17
by simonrg
cpighin wrote:Thanks simonrg
Since i would prefer to avoid the renaming of devices, is it possible to modify your script in order to consider only a device with a specific name (for example OcchioMagicoFibaro-PIR)?
You can modify it however you like -
Probably the easiest way to work with your device name is:
v=tostring(tc)
-- Look for a device name which ends in PIR
if (v:sub(-3,-1) == 'PIR') then
-- Remove -PIR from the device name and then turn that device on
c=v:sub(1, -5)
print(tmess)
would just take the PIR off the end.
Alternatively just write yourself from scripts from scratch, a script_device_name.lua which turns on the light whenever the PIR is detected, then a script_time_name.lua which turns the light off when the last update was x minutes ago. How to do this is in the more flexible scripts.
Posted: Friday 21 August 2015 15:58
by cpighin
Simonrg, few days ago you corrected my LUA file that now works fine lighting On my lamp after a motion detection.
Now I would like to improve the system to ensure that the lamp comes On when the sensor detects motion and stays On unless no movements are detected for x time (120 sec. as an example).
You have just wrote
simonrg wrote:Alternatively just write yourself from scripts from scratch, a script_device_name.lua which turns on the light whenever the PIR is detected, then a script_time_name.lua which turns the light off when the last update was x minutes ago. How to do this is in the more flexible scripts.
and I understand that I can use the LUA file you corrected as the one that turns On the light and a new script_time_name.lua which turns the light Off when the last update was 120 minutes ago, eventually using parts of your article mentioned above.
Am I write?
Claudio
Posted: Friday 21 August 2015 16:35
by simonrg
cpighin wrote:You corrected my LUA file that now works fine lighting On my lamp after a motion detection.
Am I right?
Claudio
Claudio, yes you can use your original script to turn the light on:
-- ~/domoticz/scripts/lua/script_device_occhio.lua
And then just a time script to turn it off after 120minutes.
Simon
