Solar Edge web access does not work anymore
Posted: Sunday 08 November 2026 12:20
by theo11
Since several days my web access via the API Key to Solar Edge does not work anymore.
I have "talked" to AI virtual assistant and this is the answer:
De API-sleutel in het monitoringportaal is vervangen. Systeemeigenaren gebruiken nu het nieuwe ontwikkelaarsplatform met OAuth-toegang.
Is there a new Solar Edge web access in Domoticz using OAuth authentication?
Kind regards
Theo.
Re: Solar Edge web access does not work anymore
Posted: Sunday 08 November 2026 12:33
by gizmocuz
Are you running on the latest beta version? If not, upgrade, check the hardware settings, and check if this solved it (should be)
Posted: Sunday 08 November 2026 12:58
by theo11
I have updated to the beta version and I see the new parameters for Solar Edge via Web API.
Can I create an OAuth2 account myself or I have ask the company who installed the solar panels?
Kind regards,
Theo.
Posted: Sunday 08 November 2026 13:53
by gizmocuz
Did you try what is written in the hardware setup?
I am quite sure you can do this yourself, but you will find out when you perform the steps first.
Posted: Monday 09 November 2026 10:48
by imautohuttraeger
A.f.a.i.k., creating an API key by a user account is not possible anymore since two years or so. At least I could not create it anymore 1½ years ago. It can only be done with an installer account. I guess this is the same with the new OAuth2 account.
Option 1: Ask your installer to do this. But my installer was not prepared to do it because he said, he has to ensure that no adjustments deep inside the system are made. At least as long as I want his support and warranty. A pure read-only access does not exist.
Option 2: Apply for a "self-installer-account". You must pass some online exams (watch videos and make some multiple-choice tests).
Option 3 (preferred): Use modbus real-time connection directly to the inverter. Of course his only works if the specific model of your inverter supports that (some older models don't)
Finally I have decided not to use the API, because luckily my inverter can be accessed via modbus and thanks to @addiejanssen s plugin it works. And he is currently even just working on lifting it up to an updated library-environment.
viewtopic.php?t=34039
https://github.com/addiejanssen/domotic ... tcp-plugin
Posted: Monday 09 November 2026 11:42
by gizmocuz
Did you 'guess' or did you try it?
Posted: Monday 09 November 2026 13:38
by imautohuttraeger
gizmocuz wrote: Monday 09 November 2026 11:42
I am not sure what you mean
I
tried to create an API with my simple user account and the option was not present in the menu of the Web-Monitoring (1½ years ago)
I
was guessing it is the same now with the new OAuth2 account and I just
did log in with my user account and could not see anything.
I
did ask my installer to create it (old one without OAuth) and he refused.
I
learned in a Facebook user group that you can apply for a "Self-Installer" and have to qualify for it through an online learning process.
I
do use modbus.
Posted: Monday 09 November 2026 13:45
by gizmocuz
Okey thank you for verifying.
Guessing it does not actually mean the same as tried it.
Posted: Monday 09 November 2026 13:57
by imautohuttraeger
But I might, of course, have overlooked something, which is why I prefaced my post with "A.f.a.i.k."
