Power widget only shows data from 1 phase
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
bldewit
Domoticz version: Stable
Post by bldewit »
In my custom dashboard I use "P1 electricity"-widget. The data it shows is for 1 phase, I have however a 3 phase system. Therefore the data it shows does not represent the total power usage for my house. Should I alter some settings and if so, which one(s)?
Running on rPi 4b (main) and rPi 3b (somfy), both RFLink
IthoRemote, Xiaomi Gateway, KAKU
gizmocuz
Re: Power widget only shows data from 1 phase
Post by gizmocuz »
The P1 Electricity widget shows the Usage of the P1 Smart Meter device, which is the total over all phases as the meter reports it. Which hardware do you use to read the meter (P1 USB/serial, HomeWizard, a plugin), and what does the P1 device show on the Utility page compared to the widget? If the Utility device also shows only one phase, it is the meter or hardware that delivers it that way.
bldewit
Post by bldewit »
"Power" shows 2 values, e.g. "2782 Watt, -104 Watt". Widget iterm "Grid" then shows 104 in green, "House" 2782, solar just some 160Watt yield at that time.Image
gizmocuz
Post by gizmocuz »
Are you using a P1 smart meter with a default USB cable to Domoticz? Or a script that generates this device?
bldewit
Post by bldewit »
gizmocuz wrote: Monday 02 November 2026 8:31 Are you using a P1 smart meter with a default USB cable to Domoticz? Or a script that generates this device?
I am using a P1 wifi connected module (ESP based)...
