Lua script execution exceeds maximum number of lines
Posted: Monday 19 October 2026 8:44
I have two dzvents scripts which use the JSON module and run every minute.
If i enabled these two scripts (A and B), A works well but B get an error 'Lua script execution exceeds maximum number of lines'
If i disable A, B works well.
If A run "every 2 minutes" and B "every minute", B get an error only the same minute A is running.
The JSON module seems not purge data between the dzvents scripts running in the same minute.
Do you have an idea to solve this problem?
