[dzVents] EDF Tempo (France): today/tomorrow colour, red-day risk at D+2, red days left – free JSON API, no key
Posted: Friday 16 October 2026 16:20
For those of you in France on the EDF Tempo tariff, here is a dzVents script that keeps the Tempo colour in Domoticz and warns you when a red day is coming. In full transparency: calendrier-tempo.fr is an independent project I run, a free site (not affiliated with EDF or RTE), and the script uses its API. No account, no token, no API key.
What it does:
Setup:
All fields are documented here: https://calendrier-tempo.fr/api-tempo
Data is CC BY 4.0, and every past forecast is published next to the real colour, errors included: https://calendrier-tempo.fr/historique-previsions
Feedback, bug reports or ideas for other fields are very welcome.
Jean-Pierre
What it does:
- 2 Alert sensors: today's and tomorrow's official colour (green = BLEU, yellow = BLANC, red = ROUGE, grey while tomorrow is not published yet)
- 1 Percentage sensor: probability of a red day at D+2 (forecast)
- 1 Custom sensor: red days left in the season
- A Domoticz notification (once per date) when the D+2 red risk reaches 50 % (adjustable)
- /api/today and /api/tomorrow: {"status":"ok","date":"2026-10-17","couleur":"BLEU","code":1}; status is "unavailable" until tomorrow's colour is published
- /api/predictions: day-by-day forecast up to D+15, with probabilite_bleu / probabilite_blanc / probabilite_rouge
- /api/remaining: days left per colour in the season
-- EDF Tempo (France): today's and tomorrow's colour, red-day risk at D+2,
-- red days left. Source: free JSON API of calendrier-tempo.fr (no key)
-- Put the name (or idx) of your devices, or nil to skip one.
local DEVICES = {
today = 'Tempo today', -- Alert sensor
tomorrow = 'Tempo tomorrow', -- Alert sensor
redRiskD2 = 'Tempo red risk D+2', -- Percentage sensor
redLeft = 'Tempo red days left', -- Custom sensor
local NOTIFY_THRESHOLD = 50 -- notify if red risk at D+2 >= 50 % (nil = never)
local API = 'https://www.calendrier-tempo.fr/api/'
local LEVEL = { BLEU = 'ALERTLEVEL_GREEN', BLANC = 'ALERTLEVEL_YELLOW', ROUGE = 'ALERTLEVEL_RED' }
timer = { 'every 30 minutes' },
httpResponses = { 'tempo_today', 'tempo_tomorrow', 'tempo_remaining', 'tempo_predictions' },
data = { lastNotified = { initial = '' } },
logging = { marker = 'Tempo' },
local function device(key)
if DEVICES[key] then return domoticz.devices(DEVICES[key]) end
-- Update an Alert sensor only when the value changes
local function setAlert(d, level, text)
if d and (d.text ~= text or d.color ~= level) then
d.updateAlertSensor(level, text)
if item.isTimer then
for _, route in ipairs({ 'today', 'tomorrow', 'remaining', 'predictions' }) do
domoticz.openURL({ url = API .. route, callback = 'tempo_' .. route })
return
if not (item.ok and item.isJSON and item.json and item.json.status) then
domoticz.log('No usable response for ' .. item.trigger ..
' (HTTP ' .. tostring(item.statusCode) .. ')', domoticz.LOG_ERROR)
return
local j = item.json
if item.trigger == 'tempo_today' or item.trigger == 'tempo_tomorrow' then
local isTomorrow = (item.trigger == 'tempo_tomorrow')
local d = device(isTomorrow and 'tomorrow' or 'today')
if j.status == 'ok' and LEVEL[j.couleur] then
setAlert(d, domoticz[LEVEL[j.couleur]], j.couleur)
-- /api/tomorrow returns "unavailable" until the colour is published
setAlert(d, domoticz.ALERTLEVEL_GREY, isTomorrow and 'Not published yet' or 'Unknown')
elseif item.trigger == 'tempo_remaining' then
local d = device('redLeft')
if d and j.status == 'ok' and j.remaining then
d.updateCustomSensor(j.remaining.ROUGE)
elseif item.trigger == 'tempo_predictions' and j.status == 'ok' then
-- The list starts today; look for the D+2 date
local t = os.date('*t')
local dateD2 = os.date('%Y-%m-%d', os.time({ year = t.year, month = t.month, day = t.day + 2, hour = 12 }))
for _, p in ipairs(j.predictions or {}) do
if p.date == dateD2 and tonumber(p.probabilite_rouge) then
local risk = math.floor(100 * p.probabilite_rouge + 0.5)
local d = device('redRiskD2')
if d then d.updatePercentage(risk) end
if NOTIFY_THRESHOLD and risk >= NOTIFY_THRESHOLD and domoticz.data.lastNotified ~= dateD2 then
domoticz.notify('Tempo', 'Red day likely on ' .. dateD2 ..
' (risk ' .. risk .. ' %, forecast)', domoticz.PRIORITY_HIGH)
domoticz.data.lastNotified = dateD2
}- Setup > Hardware: add a "Dummy (Does nothing, use for virtual switches only)" hardware, e.g. named Tempo.
- Click "Create Virtual Sensors" on it: two Alert sensors ("Tempo today", "Tempo tomorrow"), one Percentage ("Tempo red risk D+2") and one Custom sensor ("Tempo red days left", axis label: days).
- Setup > More Options > Events: new dzVents script, paste the code, check the device names at the top (idx works too, or nil to skip one), tick "Event active" and save.
Jean-Pierre
