AWTRIX NG
galadril
Domoticz version: latest
AWTRIX NG
Post by galadril »
I wrote a script for the AWTRIX NG firmware (the Ulanzi / 52x16 clocks) that turns the panel into a small animated picture of your Domoticz house. It reads the normal Domoticz JSON API, so there's no plugin or MQTT bridge to set up.
https://awtrix.de/script/YWyVfrGSl3Up
What it shows
• Grid: pulses run into the house while you're buying power. They turn green and run back out to the left while you're selling. A still cable means a quiet house.
• Solar: a beam of light runs from the sun down onto the roof. It's brighter and faster the more you generate.
• Battery: a cell on the right, filled by charge level (green, amber, red). A spark climbs while it charges and falls while it drains.
• EV charger: a car on the left takes a lead from the house while it charges.
• Gas and water: gas rises up the riser and leaves as chimney smoke. Water runs down the pipe while it's really flowing.
• Weather, from your own sensors: cloud cover dims the sky and hides the sun above about 2/3. Rain falls across the picture and leans with the wind. Below freezing it turns to snow and the grass goes white.
• Rooms: windows light up for lamps that are on and flicker on motion. A door contact left open turns amber and pulses.
Everything is optional. With only a thermometer you still get a house, a sun and a number.
galadril
Re: AWTRIX NG
Post by galadril »
Some other AWTRIX NG smart home scripts i made
Weather
https://awtrix.de/script/myN7wJkBqNNX
Air quality
https://awtrix.de/script/2LUoWJggz4xF
Energy Prices
https://awtrix.de/script/2LHThFxcv65F
galadril
Re: AWTRIX NG
Post by galadril »
This works on a Ulanzi TC002 Pixel clock:
https://www.ulanzi.com/en-eu/products/t ... l-clock-ii
galadril
Re: AWTRIX NG
Post by galadril »
So these script above run on the clock directly. if you want to push data/screens/notifications/etc from Domoticz, there is also a Python Plugin
https://github.com/galadril/Domoticz-AWTRIXNG-Plugin
imautohuttraeger
Re: AWTRIX NG
Post by imautohuttraeger »
Very nice. However, for me, it's too pixelated for this particular use case. But I really do like the approach of getting everything nicely displayed and animated from the existing Domoticz devices without the need of further customization. I wonder if there is something similar for higher resolution displays.
EDIT: Maybe simply for usage with the HTML Widget of the dynamic dashboard. Or a separated HTML page in general that resides on the RasPi.
Stop, look and listen.
galadril
Re: AWTRIX NG
Post by galadril »
imautohuttraeger wrote: Saturday 10 October 2026 11:40 Maybe simply for usage with the HTML Widget of the dynamic dashboard. Or a separated HTML page in general that resides on the RasPi.
Well with custom widget support people can indeed think of all kinds of widgets to build, that does not come out of the box in Domoticz indeed.
I have a PR open for that on Domoticz, but i guess a different topic ;)
