SolarEdge API: Error getting http data (Sites)
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
gbonny
Post by gbonny »
Hi I just upgraded my Domoticz from 2026.3 to 2026.4 on my Ubuntu 24.04.5 VM. So far so good.
When I look at the logging I see an error for my "SolarEdge via Web API" hardware every 5 min (I'm not sure it was there already with 2026.3):
Error: SolarEdge_API: Error getting http data (Sites)!
It seems the code (https://github.com/domoticz/domoticz/bl ... dgeAPI.cpp line 401) is using this url:
When I open this url with my api-key in a browser I see this message:
"type":"about:blank",
"title":"Scheduled V1 deprecation window",
"status":503,
"detail":"The V1 Monitoring API is retired on 2026-11-01. This is a scheduled window, not an outage. Sign up and migrate at https://developer.solaredge.com/ - migration guide: https://api-docs.solaredge.com/docs/developer-platform/mxj41549n0nxk-migrating-from-v1-to-v2",
"instance":"/legacy-monitoring/sites/list",
"traceId":".."
From the SolarEdge page:
v1: GET /sites/list
v2: GET /sites
Note: Same list, new shape — response wraps results as { "sites": { "count": N, "site": [...] } }. Fields renamed (see Field renames below).
Will the above error/issue be solved with your Merge Request @gizmocuz:
https://github.com/domoticz/domoticz/pull/7028
So it seems the /sites/list is nowadays already unavailable (before the first of November).
Doler
Re: SolarEdge API: Error getting http data (Sites)
Post by Doler »
I had the same error but it stopped just after 12 o'clock. Someone at SolarEdge pushed the wrong button?
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Trixie - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
JaapB
Domoticz version: 2025.2
Post by JaapB »
Same problem here, also happened last week. Seems like they are on a live test of the new API 2 :o
hskip
Post by hskip »
I’ve compiled the update, but it’s not exactly getting any more fun...
