Domoticz Adding a Negative to the Log
Posted: Saturday 29 August 2026 0:37
I am running the latest version of Domoticz on a pi, mosquitto (Docker) is on the same pi as well as zigbee2mqtt (Docker). I have 2 new zigbee irrigation devices, SonOff SWF-ZFU, it attaches to zigbee2mqtt fine and Domoticz creates the devices fine as well. When the irrigation devices are turned on, after about 5 minutes the irrigation devices sent out a real_time_irrigation_volume. Which can be seen in zigbee2mqtt, mqtt explorer and in the Domoticz device (real_time_irrigation_volume). All looks OK.
However the following day, there is a negative value of exact the same amount in the Domoticz chart and, after checking, in the Domoticz database. There is NO sign that zigbee2mqtt or mosquitto sent this value. I monitored the mqtt traffic using mqtt explorer and no negative values were sent through mosquitto.
I repeated this several times through several days to be sure of the issue.
My question is: why is Domoticz doing this? What am I doing wrong? Can this be fixed?
