Solution to integrate the Energy page into a widget Topic is solved
pfloryann
Post by pfloryann »
I integrated the Energy page into an html widget in dynamic dashboard through an iframe, it works very well but only locally. From outside for security reasons it is blocked. What solutions would be to make it work?
Screenshot 2026-08-19 at 19-52-52 Domoticz.png (191.45 KiB) Viewed 1124 times
Last edited by pfloryann on Wednesday 26 August 2026 9:48, edited 1 time in total.
Domoticz on Raspberry Pi 4 Debian 13 x64
Zigbee2mqtt and zigbee devices (Xiaomi, Ikea,Tuya, Philips, Osram), Broadlink, Solar power Victron Energy, Yeelight, Xiaomi Purifier Pro, Roborock S5, Gree AC, JBL soundbar, Philips Android Tv
pfloryann
Re: Solution to integrate the Energy page into a widget?
Post by pfloryann »
Finally, we managed to display the energy page without the domoticz header in an html widget in Dynamic Dashboard.
After adding the html code below to the html widget(must check Allow backend API access ) and the mentioned settings, it will be displayed exactly as in the image above.
<div style="width:100%; height:850px; overflow:hidden;">
<iframe
src="/#/Energy" scrolling="no"
style="
width:100%;
height:950px;
border:0;
margin-top:-255px;
margin-left:-25px
</iframe>
</div>
*height and margins it must be set according to the size of your widget.
Last edited by pfloryann on Monday 28 September 2026 9:44, edited 2 times in total.
Doler
Post by Doler »
Works great.
Mark: Domoticz latest Beta on Virtual machine (Proxmox) running Debian Trixie - Z-Stick 7 - RFXCom - P1 - SolarEdge - Dahua - Philips Hue - Docker - Zigbee2mqtt (latest, docker) via python plugin - Zwave-js-ui (latest, docker) - dzVents - Nodered
gizmocuz
Post by gizmocuz »
We already have a energy dashboard widget that should display all stats? (except the custom sensors)
Doler
Post by Doler »
You are absolutely right but the Energy Dashboard page adds to that the energy flow so you see at a glance what is going on. The Energy Dashboard widget shows (of course) the same values but is more static. It would be nice if the Energy Dashboard page could be added natively as a widget.
