Error Calculating flow from total usage device  [Solved]
dthompson
Post by dthompson »
I'm trying to create a virtual point that will show the actual usage of water every 5 minutes from my water meter which is total consumed.
But, i keep getting this error no matter what i attempt to reference for the device value:
2026-08-16 18:14:00.473 Error: dzVents: An error occurred when calling event handler Water usage
2026-08-16 18:14:00.473 Error: dzVents: ...moticz/scripts/dzVents/generated_scripts/Water usage.lua:12: attempt to index a nil value (global 'device')
Here's the code i'm using:
        timer = {
            'every 1 minutes' -- This is your time trigger
        devices = {
            'Total water used' -- CHANGE THIS to your actual device name
    execute = function(domoticz, timer)
        -- 1. Get the current reading
        local currentFlow = device.sensorValue -- Use .sensorValue, .flow, or .state depending on device type
        -- 2. Retrieve the last saved reading
        local lastFlow = domoticz.variables('LastValue').sensorValue
        -- 3. Calculate the difference
        local difference = currentFlow - lastFlow
        -- 4. Log the results to the Domoticz log
        domoticz.log('Current Flow: ' .. currentFlow .. ' L/m', domoticz.LOG_INFO)
        domoticz.log('Previous Flow: ' .. lastFlow .. ' L/m', domoticz.LOG_INFO)
        domoticz.log('Calculated Difference: ' .. difference .. ' L/m', domoticz.LOG_INFO)
        -- 5. OPTIONAL: Update a dummy device with the difference
        -- domoticz.devices('Flow Difference Device').updateCustomSensor(difference)
        -- 6. Update the persistent variable for the next run
        domoticz.variables('TotalValue').set = currentFlow
And, here are the devices i'm using:
223 MQTTmapper powerpi/SCMplus/71280747 1 Total water used General Custom Sensor 101119 Gal - - 2026-08-16 18:20:16
224 Virtual sensors 00082224 1 Water usage General Custom Sensor 0 Gal - - 2026-08-15 21:24:00
The actual water meter is being read via an usb SDR dongle on a RPI 3b running rtl_433 and using MQTT to pass the value to Domoticz thru the MQTTmapper.
Domoticz server:
OS: Raspberry PI OS Bookworm - fully updated
Domoticz : 2026.2
So, what am i doing incorrectly? I feel like i've tried every combination of value, curentvalue, counter, etc. and nothing seems to work.
Thanks,
Darryl
Re: Error Calculating flow from total usage device
Line 12 is
But there is no device as in the execute a timer is given ( execute = function(domoticz, timer) ).
So change the execute (change 'timer' into 'item') and check if item is a timer or a device trigger.
Or change line 12 into
local currentFlow = domoticz.devices('Total water used').sensorValue
dthompson
Post by dthompson »
So, having this in the beginning doesn't define the device?
devices = {
This is just after the timer = declaration.
Thanks ,
Darryl
dthompson
Post by dthompson »
Ok, so i modified my code as suggested and received this error:
2026-08-17 17:32:00.822 Error: dzVents: ...moticz/scripts/dzVents/generated_scripts/Water usage.lua:12: attempt to index a nil value (global 'dz')
Here's my new code:
timer = {
local lastFlow = dz.variables('LastValue').state
domoticz.devices('Water usage').updateCustomSensor(difference)
dthompson
Post by dthompson »
I think i corrected the code for that error. Thank you for walking me thru this.
But, now i have this error:
2026-08-17 17:35:00.934 Error: dzVents: ...moticz/scripts/dzVents/generated_scripts/Water usage.lua:15: attempt to perform arithmetic on a nil value (local 'lastFlow')
And, this new code:
timer = {
local lastFlow = domoticz.variables('LastValue').state
Thanks,
Darryl
dthompson
Re: Error Calculating flow from total usage device  [Solved]
Post by dthompson »
I think i finally got it to work. Thank you for pointing me in the right direction. I'm no longer getting any errors, and it is calculating and passing the results to the virtual point i created.
Here's the final code:
timer = {
'every 5 minutes' -- This is your time trigger
local lastFlow = domoticz.variables('LastValue').value
domoticz.variables('LastValue').set(currentFlow)
Thank you again!!
Darryl
