http action command not working
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
edwin1234
Domoticz version: 2021.1
Post by edwin1234 »
I always sent an ON command and an OFF command through Domoticz, such as:
http://192.168.2.142/control?cmd=gpio,4,1
This always worked fine, but since the latest version of Domoticz, it no longer works.
I have the correct IP addresses configured under the security settings.
I treid it in a normal webbrowser and their it worked.
What could be causing this to stop working?
Edwin
Edit waltervl, changed title.
Re: Commando not working
This seems to be not a Domoticz command but esphome or espeasy or something similar.
Edit: it is indeed EspEasy and not a Domoticz command: https://espeasy.readthedocs.io/en/lates ... mmand.html
Domoticz API commands can be found here: https://wiki.domoticz.com/Domoticz_API/JSON_URL%27s
imautohuttraeger
Domoticz version: latest
Post by imautohuttraeger »
waltervl wrote: Thursday 13 August 2026 19:47 This seems to be not a Domoticz command but esphome or espeasy or something similar.
I think @edwin1234 does not mean, that it is a domoticz command. It seems that he is using this EspEasy URLs for on and off actions of a device.
And these URLs work in a browser but not, if Domoticz is sending it out
Stop, look and listen.
Gravityz
Post by Gravityz »
and if you use this
http://192.168.2.142/control?cmd=event,GPIO_ON
and in your ESPeasy
On GPIO_ON Do //event is initiated from domoticz
GPIO,4,1
i used to use it this way but moved to esphome so can not test.
see this page under HTTP call
https://www.letscontrolit.com/wiki/inde ... #HTTP_call
edwin1234
Re: http action command not working
Post by edwin1234 »
Thanks for the answers,
But i found out that there was a process on my pi5 that took over my domoticz port and that was the reason why my switch with the http on off command didn’t work.
