Domoticz revision
Posted: Wednesday 05 August 2026 9:54
by HansieNL
Hello all,
Maybe I don't look good but I can't find the revision of the installed Domoticz version.
In the about box there's no revision version shown only the main version.
Can someone tell me how to get the revision?
Thanks in advance.
Re: Domoticz revision
Posted: Wednesday 05 August 2026 12:53
by jannl
It is on top of the screen, below 'Domoticz' in the upper left corner. On a mobile only in landscape mode
Posted: Wednesday 05 August 2026 13:22
by HansieNL
Thanks jannl.
I see the main version number, but not a revision number.
With an older beta version (before the complete restyling) the revision was shown between parenthesis () behind the main version.
Would be great if the revision will be shown at the about box too.
Posted: Wednesday 05 August 2026 14:01
by Rik60
Same problem here. Running 2026.3 beta, updated today
Posted: Wednesday 05 August 2026 14:08
by HansieNL
Trying
http://192.168.2.2:8080/json.htm?type=c ... getversion and the answer is without the revision number too?
In the past it was shown this way "version" : "2023.1 (build 15331)" now I just get "version" : "2026.3"
Posted: Wednesday 05 August 2026 17:23
by Rik60
"DomoticzUpdateURL" : "
https://www.domoticz.com/download.php?c ... ne=aarch64",
"HaveUpdate" : false,
"Revision" : 18180,
"SystemName" : "linux",
"UseUpdate" : true,
"build_time" : "2026-08-05 13:24:03",
"db_size" : 19188736,
"dzvents_version" : "3.1.11",
"hash" : "8b245beb5",
"python_version" : "3.13.5 (main, Jul 15 2026, 20:25:40) [GCC 14.2.0]",
"status" : "OK",
"title" : "GetVersion",
This is the answer
Posted: Wednesday 05 August 2026 17:40
by HansieNL
@Rik60
As far as I know is this revision version the latest revision available for download and not the installed version.
I get revision 18185, but I'm sure I don't have that one installed.
Posted: Wednesday 05 August 2026 19:09
by HansieNL
Looks like problem will be fixed:
Little info - Build version missing #6943
https://github.com/domoticz/domoticz/issues/6943
FIXED
Posted: Friday 07 August 2026 8:59
by Gravityz
thought it was a new feature.
some time a go i started naming my docker container with the build included so it was not a big deal for me.
glad is it back now
Posted: Friday 07 August 2026 14:07
by HansieNL
I now have created a dzvents script that sends the version as for example 2026.3.18185 to a variable. This script will run at every domoticz start.
at_startup = true
execute = function(domoticz)
local rawVersion = tostring(domoticz.settings.domoticzVersion)
local currentVersion = rawVersion:gsub("%s*%(build%s*(%d+)%)", ".%1")
local var = domoticz.variables('domoVer')
local storedVersion = var.value
if currentVersion ~= storedVersion then
domoticz.log('Nieuwe Domoticz versie: ' .. currentVersion, domoticz.LOG_INFO)
var.set(currentVersion)
