Update frequency FGBS-222 in Zwave JS UI
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
hjzwiers
Post by hjzwiers »
I have a problem that i think is localized in the Zwave JS UI, the frequency of the updates. How can you control it?
jannl
Domoticz version: 2026.1.x
Re: Update frequency FGBS-222 in Zwave JS UI
Post by jannl »
Zwave js has a webinterface on port 8091, may be you could something there.
hjzwiers
Post by hjzwiers »
If i do a manual update of Multilevel Sensor v11 it updates the sensor values and Domoticz follows almost immediately, i dont see how doing something at the port would change that. Its something within Zwave JS UI
jannl
Post by jannl »
Without debugging in zwave js I also have no clue. You could read the documentation of zwave js (which obviously will point you to its web interface).
