2026.3 libwebem change results in unauthenticated admin access Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
domovincent
Domoticz version: 2026.2
Post by domovincent »
Sorry for cross posting, but maybe it's okay because my original post is a reply to the release, and it won't be seen quickly enough.
Version: 2026.3
Platform: Linux binary
Plugin/Hardware: core webserver
Description:
- New libwebem ignores proxy headers by default. Forwarded headers are now ignored unless the new trusted_proxy_header_family setting is explicitly configured. Its new default is None.
- Domoticz does not configure this new header-family setting.
- Domoticz sees trusted proxy IP, and grants all clients admin access without login.
This applies to: setups with trusted reverse proxy in front of Domoticz with X-Forwarded-For to forward real client IPs.
Fix: Add headers explicitly to the libwebem config:
https://github.com/domoticz/domoticz/pull/6937
We probably want to do a quick patch release here.
Domoticz (RPI 5), Z-Wave, 433, MQTT, ANWB-energy. Happy user since 2017
rugspin
Re: 2026.3 libwebem change results in unauthenticated admin access
Post by rugspin »
Just a question on the above.
In my local network, I use nginx as a revers proxy on the same host as domoticz is running, just to have a decent url and not always have to put the port number. It looks like that and was working fine so far:
    # domoticz
    # domoticz
    location = /domoticz {
        return 301 /domoticz/;
    location ^~ /domoticz/ {
        auth_basic off;
        proxy_pass http://127.0.0.1:8085/;
        proxy_ssl_trusted_certificate /opt/domoticz-docker/domoticz-com.pem;
        proxy_ssl_verify on;
        proxy_ssl_verify_depth 2;
        proxy_redirect off;
Now when I do the
https://<hostnname>/domoticz/
I get error: "403 Forbidden"
But with
everything is fine.
I'm not much of an expert in reverse proxies, but is that related to the above problem with revers proxies?
Would be glad about some help.
domovincent
@rugspin that is a different issue. There's some nice reverse proxy examples on the wiki. The logs of your proxy are usually very helpful as well.
On the main topic: the latest beta fixes the issue (About page states Compile Date 2026-08-02 18:55:45). Just installed and tested. X-Forwarded-For works as expected.
rugspin
Post by rugspin »
domovincent wrote: Monday 03 August 2026 9:23 @rugspin that is a different issue. There's some nice reverse proxy examples on the wiki. The logs of your proxy are usually very helpful as well.
Somehow, my reverse proxy was affected. The 2026-08-02 18:55:45 version showed that strange behavior.
Now, I have 2026-08-03 16:43:35 and it works as before.
Thanks for the help.
domovincent
Oh, well, that's unexpected. But good news nonetheless. :lol:
gizmocuz
Post by gizmocuz »
You need to proxy to HTTP, NPM is doing the certificates
