Issue with integration of Domoticz and Matter server: Unable to switch On/Off
Posted: Thursday 23 July 2026 10:06
I am experiencing a problem controlling a Matter On/Off device from Domoticz using the Python Matter Server.
The Matter device is discovered correctly and state synchronization works in one direction, but switching the device from Domoticz fails.
Environment
Domoticz: 2026.2 (build 18141)
Hardware type: Matter (python-matterjs-server)
Matter Server Docker image:
ghcr.io/matter-js/python-matter-server:stable
Matter Server version:
2025.7.0
Platform:
Synology DS918+
DSM 7.x
Container Manager
Docker network mode: host
Docker compose:
services:
matter-server:
image: ghcr.io/matter-js/python-matter-server:stable
container_name: matter-server
restart: unless-stopped
network_mode: host
security_opt:
- apparmor:unconfined
volumes:
- ./data:/data
Matter device
KlikAanKlikUit MAGC-2300 (Matter smart plug/switch)
Commissioned using Apple Home.
Added to the Python Matter Server via Multi-Admin.
Behaviour
- Works correctly
Apple Home can switch the device.
Matter Server receives the correct state.
Domoticz discovers the device.
Domoticz correctly updates the device status when it is switched from Apple Home.
- Does not work
Switching the device from Domoticz immediately fails.
Domoticz logs:
Status: User: admin initiated a switch command (.../On)
Error: Matter: Server error:
type object 'Commands' has no attribute 'on'
Matter: Light/Switch (...)
Matter Server logs:
AttributeError:
type object 'Commands' has no attribute 'on'. Did you mean: 'On'?
File "/usr/local/lib/python3.12/site-packages/matter_server/server/client_handler.py", line 213, in _run_handler
raise err
File "/usr/local/lib/python3.12/site-packages/matter_server/server/client_handler.py", line 196, in _run_handler
result = await result
File "/usr/local/lib/python3.12/site-packages/matter_server/server/device_controller.py", line 703, in send_device_command
command_cls = getattr(cluster_cls.Commands, command_name)
Analysis
The Python Matter Server attempts:
where command_name appears to be:
on
However, the current CHIP SDK exposes:
Commands.On
Commands.Off
which results in the AttributeError.
It is therefore unclear whether:
Domoticz sends "on" instead of "On", or
the Matter Server converts "On" to "on" before calling getattr().
Since the Matter Server traceback indicates the exception occurs inside send_device_command(), it may be helpful to log the received command_name before the getattr() call.
Expected behaviour
Clicking On or Off in Domoticz should switch the Matter device successfully.
Additional observations
State synchronization from Apple Home → Matter Server → Domoticz works perfectly.
Only Domoticz → Matter Server → device fails.
Environment
2025.7.0
Platform:
Synology DS918+
DSM 7.x
Container Manager
Docker compose:
services:
matter-server:
network_mode: host
security_opt:
volumes:
- ./data:/data
Matter device
Behaviour
- Works correctly
- Does not work
Domoticz logs:
Matter Server logs:
AttributeError:
raise err
Analysis
on
Commands.On
Commands.Off
Expected behaviour
