today i had my meter swapped for a 3 phase one.
I am using the RFXTRX433XL with P1 meter option enabled
after reboot(accept new hardware on) a lot of new devices were discovered
My p1 energy device stayed the same and is working and receiving data
The gasmeter device did not change either but it is not receiving/updating
Also there is no new gasmeter device created
i googled and noticed i had to couple the gasmeter to the p1 meter again(push red button, push and hold for 8 seconds)
i got a message that the gasmeter is coupled to the p1 meter
after that still no new data received
in the log i see this so it should work but why is the gasmeter in domoticz not receiving anymore
2026-07-22 15:47:31.719 Status: RFXtrx433XL: Meter reports as ESMR 5.0
2026-07-22 15:47:31.750 Status: RFXtrx433XL: Current electricity tariff: Low
2026-07-22 15:47:31.915 MQTT Auto Discovery Client Gateway: Temp/THR128/138, THC138 (CV Delta)
2026-07-22 15:47:31.923 Status: RFXtrx433XL: Found gas meter on M-Bus channel 1
sure i can delete my gasmeter device and see if it creates a new one but then i loose my complete history
does anynody know how to solve this
Weird thing nr 2. the p1 meter is currently reporting Low tariff while it should report high tariff
gasmeter not working after meter swap Topic is solved
- Domoticz version: 2026.3
Re: gasmeter not working after meter swap
did you check the wiki on the gasmeter not reporting subject? https://wiki.domoticz.com/Dutch_DSMR_sm ... g_any_data
Gravityz
yes i though that would solve it but still not.
i called liander and they state it will probably take a couple of days beforte the gasmeter shows up in the p1 meter.
i recoupled the gasmeter to the p1 meter.
when i look at the physical p1 meter it states Gasmeter but shows no value, only a serialnumber(which does not match my gasmeter.
so for now i think i will wait to see if the magic will happen.
maybe indeed the technician forgot to remove the old gasmeter and the coupling of the new one takes time.
thanks for the help sofar
Gravityz
just tested by using the liander site.
there is a button which you can use to test the meter and give readouts.
tried it but no readouts.
i think indeed things need to settle in
Gravityz
UPDATE.
Gasmeter came alive this morning and is working again.
thanks @waltervl for your help
