House consumption as a device
imautohuttraeger
Domoticz version: latest
Post by imautohuttraeger »
The energy dashboard already shows the house consumption with actual power in Watt and daily Energie in kWh.
I am looking for an easy way to get these data into a virtual utility device type "general, kWh". As the calculation of these data is already done in the background obviously, I thought I could maybe pick the data via dzvents script, but without extra calculation, so that the figures are really identical.
Is this possible - and if yes: How?
Stop, look and listen.
madpatrick
Domoticz version: 2026.1
Re: House consumption as a device
Post by madpatrick »
If you have data available you can do almost everything with it
Make a dummy devices and place the data into it
imautohuttraeger
Sure. But where do I get the data from? I only see it in the right bubble of the energy dashboard (actual power and daily energy). So it is calculated and displayed already but I don't know how to address these data in a script.
I want to avoid of calculating it in parallel with possible slightly different results and additional unnecessary workload for Domoticz
madpatrick
You data in the Energy dashboard is defined in the settings of the Energy dashboard
This is setup by yourself. The must be devices measuring the power, otherwise you have a very smart system
imautohuttraeger
Got you. Sure. I know I can calculate it from P1, solar and batterie. I just thought I could avoid it, because the system is already doing this calculation process somewhere in the background.
As the data is calculated by the Energy dashboard itself it is not put into a device.
You can use the same logic as used in the energy dashboard to calculate the house consumption and put it into an Energy device by a dzvents script.
The logic is in the file: https://github.com/domoticz/domoticz/bl ... troller.js
  fTotalHomeUsage (kWh today):
  Grid used + Solar generated − Grid returned
    + Battery discharged (if configured)
    − Battery charged (if configured)
imautohuttraeger
Thanks. With AI help, I could make this script and it works well. (Comments by Claude in German - sorry)
        devices = { 743, 747, 746, 906 }
        local pvcounter = domoticz.devices(743)
        local importcounter = domoticz.devices(747)
        local exportcounter = domoticz.devices(746)
        local battery = domoticz.devices(906)
        local dummyVerbrauch = domoticz.devices(816)
        -- Aktuelle Leistung berechnen
        -- battery.actualWatt: negativ = Entladen (liefert zusätzlich Energie an den Haushalt
        -- -> muss addiert werden), positiv = Laden (Energie fließt in die Batterie statt in
        -- den Haushalt -> muss abgezogen werden)
        local aktuelleLeistung = pvcounter.actualWatt + importcounter.actualWatt - math.abs(exportcounter.actualWatt) - battery.actualWatt
        -- Nur den Watt-Wert übergeben; kWh übernimmt Domoticz selbst (Energy read = computed)
        dummyVerbrauch.update(0, string.format("%.1f;0", aktuelleLeistung))
Maybe grid import and export could even be fetched directly from the P1 device, but I had it as separate devices already.
