Dynamic dashboard Calendar not updating
Posted: Friday 10 July 2026 21:48
The Dynamic dash is a really, really good addition to Domoticz which I like a lot. However I have a problem with the Calendar widget.
I'm using an .ics link to a (Nextcloud) calendar. Initially when configuring the widget it works great. However it seems that updates are not shown. Even refreshing the widget does not update the calendar items.
I checked the ics url directly and confirmed the correct calendar items are there. Also using other browsers and disabling cache doesn't make any difference.
Has anyone an idea how to resolve this issue?
Thanks,
--Gerard
EDIT: Some additional info: When I view the debug logs is see the call to the calendar server as something like; /json.htm?type=command¶m=fetchurl&url=<url calendar server>
Using the same command manually in the browser like http://domoticz.ip/json.htm?type=comman ... l&url=<url calendar server> will give the correct results from the calendar server. The widget however is not updating.
Thanks,
--Gerard
