again ... Error: Invalid Number sValue: '%' for device idx: '%'
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
eddieb
Post by eddieb »
I get these errrors in my logging (on both my 2025.2 and my new 18070 domoticz ..
2026-07-04 09:01:09.496  Error: Invalid Number sValue: '%' for device idx: '%'
it would be really nice for debugging if the log line tells which plugin or which device produces this ...
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / IndeVolt SF3000 / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
imautohuttraeger
Domoticz version: lat.beta
Re: again ... Error: Invalid Number sValue: '%' for device idx: '%'
Post by imautohuttraeger »
I have the same error for a long time already and haven' figured out how to find out the cause. So I am highly I interested in a tip for a good debugging procedure.
Stop, look and listen.
gizmocuz
Post by gizmocuz »
Again this is caused by a plugin or a invalid json call, nothing domoticz related.
Again we display this message to you, and again you should check to which hardware it belongs to you should be able to find the cause again.
And if you want, you can also delete this device and the message should again disappear
willemd
Post by willemd »
I only get this error when a P1device is created by a plugin and the device has not been updated with a value yet.
Look for a device without a value. That is probably the device that triggers this error.
eddieb
Post by eddieb »
gizmocuz wrote: Saturday 04 July 2026 19:19 Again this is caused by a plugin or a invalid json call, nothing domoticz related.
but which device ... which plugin ...
imautohuttraeger
In my case, the probably suspect device has disappeared from the list of devices, so I can't delete it. At least not with the means of the user front-end. I guess I would have to hard dive into SQL database amendments, but that is rather sophisticated for me ...
So there is neither a device nor a plugin that can simply be deleted or stopped.
It is a virtual utility device that once received data from a Tasmota infrared reading device by simply typing in the IDX in Tasmota's "Configure Domoticz" section. Of cause I have deleted that IDX from the Tasmota configuration and even have switched off the tasmota device and it's connection to the MQTT broker.
The virtual Domoticz device seems to still exist in a kind of "hidden" way, because sometimes it "popped up" in the list of devices for some seconds. But meanwhile even this is not happening anymore.
