Device values in notification
Posted: Friday 26 June 2026 9:25
by JeanBonnot
When using the "Notification" feature of a temperature sensor, how do I include the device's temperature value in the message?
This doesn't work : "Temp : {{temperaturedevice[34287]}} "
Thanx
Re: Device values in notification
Posted: Friday 26 June 2026 9:36
There is no way to program this from the default Edit Notifications dialog.
You cannot set a custom notification message with parameters. It can be done with for example dzvents scripting.
But the standard message contains already the temperature!
For example: If you set send notification when temperature is above 30 you will get the following notification message when temp is 32:
<Your tempdevicename> is 32.0 degrees > 30.0 degrees
Posted: Saturday 27 June 2026 23:59
by gerardvs
JeanBonnot wrote: Friday 26 June 2026 9:25
Thanx
You could use: Temp: $value
Posted: Sunday 28 June 2026 22:48
Thanks I did not know this and added it to the wiki.
You can use paramerers $name and $value to create your own custom message.
