Error with last verion of Zigbee2mqtt
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Arjan2019
Post by Arjan2019 »
Error: Zigbee2: Exception (GetValueFromTemplate): Type is not convertible to string! (Template: value_json[overload_protection])
I get this every time my oven updates
  "current": 0,
  "energy": 3.28,
  "energy_month": 0,
  "energy_today": 0,
  "energy_yesterday": 0,
  "inching_control_set": {},
  "last_seen": "2026-06-05T23:21:26+02:00",
  "linkquality": 134,
  "network_indicator": true,
  "outlet_control_protect": false,
  "overload_protection": {
    "enable_max_voltage": "DISABLE",
    "enable_min_current": "DISABLE",
    "enable_min_power": "DISABLE",
    "enable_min_voltage": "DISABLE",
    "max_current": 0,
    "max_power": 0,
    "max_voltage": 0,
    "min_current": 0,
    "min_power": 0,
    "min_voltage": 0
  "power": 0,
  "power_on_behavior": "on",
  "state": "ON",
  "update": {
    "installed_version": -1,
    "latest_version": -1,
    "state": "idle"
  "voltage": 236.54
Another error I get on a light
Error: Zigbee2: Exception (GetValueFromTemplate): Type is not convertible to string! (Template: value_json[color_options])
It looks like if I get new inforamtion of light with colors
  "brightness": 107,
  "color": {
    "x": 0.4488,
    "y": 0.4078
  "color_mode": "color_temp",
  "color_options": {
    "execute_if_off": false
  "color_temp": 352,
  "color_temp_startup": 250,
  "effect": null,
  "identify": null,
  "last_seen": "2026-06-06T08:27:25+02:00",
  "linkquality": 65,
  "power_on_behavior": "previous",
  "state": "OFF",
  "update": {
    "state": "idle"
  "update_available": false
color_options": { "execute_if_off": false give the error I think because in home assistant it's also wrong
An older version of Zigbee2Mqtt doesn't have this problem.
No respond on the issue by Zigbee2mqtt
https://github.com/Koenkk/zigbee2mqtt/issues/32181
Version: 2026.02
Platform: PI 4
Plugin/Hardware: Tuya and homewizard
jannl
Domoticz version: 2026.1.x
Re: Error with last verion of Zigbee2mqtt
Post by jannl »
I have had a similar issue with a different appliance. Turned out the appliance had a firmware update to which zugbee2mqtt already responded with an update making my setup useless untill I did the firmware update.
Backward compatibility is not always an option.
The you check if there us a firmware update?
Arjan2019
Post by Arjan2019 »
Did update the socket and didn't solve the issue
No update for the lights
jannl
Post by jannl »
You have the latest version of zigbee2mqtt?
Arjan2019
Post by Arjan2019 »
Yes I have installed the last verion and I tried de dev version both give the same errors
jannl
Post by jannl »
Did you try Domoticz latest beta? (Remember to make a backup)
gizmocuz
Post by gizmocuz »
Could you also post the config object (topic + payload) of this device sensor?
Best to follow this guide:
https://wiki.domoticz.com/MQTT_AD_Report_Problems
Arjan2019
Post by Arjan2019 »
This from the socket
https://www.zigbee2mqtt.io/devices/S60ZBTPF.html
Config:
"availability": [
"topic": "zigbee2mqtt/bridge/state",
"value_template": "{{ value_json.state }}"
"topic": "zigbee2mqtt/Oven/availability",
"availability_mode": "all",
"command_topic": "zigbee2mqtt/Oven/set",
"default_entity_id": "switch.oven",
"device": {
"hw_version": 16,
"identifiers": [
"zigbee2mqtt_0xa4c138055607ffff"
"manufacturer": "SONOFF",
"model": "Zigbee smart plug",
"model_id": "S60ZBTPF",
"name": "Oven",
"sw_version": "1.0.2",
"via_device": "zigbee2mqtt_bridge_0x00124b0021cbece4"
Switch_network_indictor:
"name": null,
"object_id": "oven",
"origin": {
"name": "Zigbee2MQTT",
"sw": "2.11.0-dev",
"url": "https://www.zigbee2mqtt.io"
"payload_off": "OFF",
"payload_on": "ON",
"state_topic": "zigbee2mqtt/Oven",
"unique_id": "0xa4c138055607ffff_switch_zigbee2mqtt",
"value_template": "{{ value_json[\"state\"] }}"
Switch_network_indicator
"availability": [
"command_topic": "zigbee2mqtt/Oven/set/network_indicator",
"default_entity_id": "switch.oven_network_indicator",
"device": {
"hw_version": 16,
"identifiers": [
"name": "Oven",
"entity_category": "config",
"name": "Network indicator",
"object_id": "oven_network_indicator",
"origin": {
"sw": "2.11.0-dev",
"payload_off": "false",
"payload_on": "true",
"unique_id": "0xa4c138055607ffff_switch_network_indicator_zigbee2mqtt",
"value_template": "{% if value_json[\"network_indicator\"] %}true{% else %}false{% endif %}"
homeassistant/switch/0xa4c138055607ffff/switch_network_indicator/config
Switch_outlet_control_project
"availability": [
"command_topic": "zigbee2mqtt/Oven/set/outlet_control_protect",
"default_entity_id": "switch.oven_outlet_control_protect",
"device": {
"hw_version": 16,
"identifiers": [
"name": "Oven",
"name": "Outlet control protect",
"object_id": "oven_outlet_control_protect",
"origin": {
"sw": "2.11.0-dev",
"unique_id": "0xa4c138055607ffff_switch_outlet_control_protect_zigbee2mqtt",
"value_template": "{% if value_json[\"outlet_control_protect\"] %}true{% else %}false{% endif %}"
Zigbee2mqtt topic
"current": 0,
"energy": 3.28,
"energy_month": 0,
"energy_today": 0,
"inching_control": "DISABLE",
"inching_mode": "OFF"
"last_seen": "2026-06-07T19:58:23+02:00",
"linkquality": 142,
"max_current": 0,
"max_power": 0,
"max_voltage": 0,
"min_current": 0,
"min_power": 0,
"min_voltage": 0
"power": 0,
"state": "ON",
"update": {
"installed_version": 8194,
"latest_release_notes": null,
"latest_source": "",
"latest_version": 8194,
"state": "idle"
"voltage": 232.56
Arjan2019
Post by Arjan2019 »
This from the light
config:
"availability": [
"topic": "zigbee2mqtt/Links Achter/availability",
"command_topic": "zigbee2mqtt/Links Achter/set/identify",
"default_entity_id": "button.links_achter_identify",
"device": {
"hw_version": 1,
"identifiers": [
"zigbee2mqtt_0x90ab96fffeb42bf5"
"manufacturer": "IKEA",
"model": "TRADFRI bulb E26/27, white spectrum, globe, opal, 1055/1100/1160 lm",
"model_id": "LED2201G8",
"name": "Links Achter",
"sw_version": "3.0.23",
"device_class": "identify",
"object_id": "links_achter_identify",
"origin": {
"sw": "2.11.0-dev",
"payload_press": "identify",
"unique_id": "0x90ab96fffeb42bf5_identify_zigbee2mqtt"
effect:
"availability": [
"command_topic": "zigbee2mqtt/Links Achter/set/effect",
"default_entity_id": "select.links_achter_effect",
"device": {
"hw_version": 1,
"identifiers": [
"enabled_by_default": false,
"icon": "mdi:palette",
"name": "Effect",
"object_id": "links_achter_effect",
"options": [
"blink",
"breathe",
"okay",
"channel_change",
"finish_effect",
"stop_effect"
"origin": {
"sw": "2.11.0-dev",
"unique_id": "0x90ab96fffeb42bf5_effect_zigbee2mqtt"
zigbee2mqtt/bridge/health
Zigbee2mqtt topic:
"brightness": 130,
"color": {
"x": 0.4488,
"y": 0.4078
"color_options": {
"color_temp": 352,
"effect": null,
"identify": null,
"last_seen": "2026-06-07T19:57:43+02:00",
"level_config": {
"linkquality": 25,
"state": "OFF",
"update": {
"installed_version": 50331683,
"latest_release_notes": "https://ww8.ikea.com/ikeahomesmart/rele ... notes.html",
"latest_source": "https://raw.githubusercontent.com/Koenk ... 102e17.ota",
"latest_version": 50331683,
"state": "idle"
mgugu
Post by mgugu »
Maybe not a problem of Zigbee2Mqtt itself but the config message it delivers for your specific device. In addition, the JSON parser of Domoticz seems to be more strict than before in recent versions.
I had similar errors with a Dingtian relay : The config message included a field like "optimistic":"false", it was OK in the past but is is rejected by recent versions of Domoticz which expects "optimistic" : false.
Since I cannot modify the Dingtian config message, the only solution I found was to mofify the config message myself and to bridge it via node-red.
I would recommand to check carrefully the data types for your device with mqtt explorer.
Would be a must in Domoticz to have an option to relax JSON parsing severity.
Arjan2019
Post by Arjan2019 »
Thanks for solving this in the last beta.
