Enphase werkt niet meer sinds update
Posted: Friday 05 June 2026 9:51
by edwin1234
Did the latest update yesterday
Everything continued to work well except hansie/enphase envoy plugin which stopped working right after the update and gives connection problems.
Has anything changed?
Thanks in advance
Re: Enphase werkt niet meer sinds update
Posted: Friday 05 June 2026 10:28
by gizmocuz
Nope, and why not use the native build in enphase hardware support?
Posted: Friday 05 June 2026 12:06
by edwin1234
Because it worked perfectly
Till the update,and i worked for a long time with the domoticz 2021. Version. And with 2026-1 it still was funtioning.
Only not with 2026-2 version.
Posted: Saturday 06 June 2026 9:55
by Gingerpale
I also experience issue with native Enphase integration since June 5th.
My log shows:
2026-06-06 09:41:30.071  Error: Solar Panels: Error getting http data! (login)
2026-06-06 09:42:31.750  Error: Solar Panels: Error getting http data! (check_jwt)
I tried to put in a new generated token in uservars, but it gives me still the same error.
Is it due to an update of Domoticz or due to a change at Enphase or something else?
Dz HW Enphase.jpg (9.17 KiB) Viewed 3338 times
Posted: Saturday 06 June 2026 10:17
by Arjan2019
Gingerpale wrote: Saturday 06 June 2026 9:55 I also experience issue with native Enphase integration since June 5th.
My log shows:
After last night update I got the same error it start just after 23:00
Posted: Saturday 06 June 2026 17:55
by Gingerpale
It is kinda weird as I keep getting the "Error getting http data! (check_jwt)" at every update interval, but some Enphase entities keep reporting, such as Enphase KWh Production and IQ microinverter power. But IQ microinverter DC/AC voltage and temperature are not updating anymore. Hence the errors???
I have added my (anonymized) settings here as well for reference.
Dz Hw Enphase settings.jpg (74.08 KiB) Viewed 3286 times
Posted: Sunday 07 June 2026 6:06
by edwin1234
I have the same ,
Also at 5june
Only usage is not working
But delivery and the inverters are ok in domoticz.
Posted: Sunday 07 June 2026 8:36
by gizmocuz
Maybe it is a backend issue?
Did not change anything in regards to polling
2026-06-04 21:02:55.268 Error: Enphase: Error getting http data! (power)
2026-06-05 06:04:31.320 Error: Enphase: Error getting http data! (power)
2026-06-05 20:43:31.872 Error: Enphase: Error getting http data! (power)
2026-06-06 13:12:45.616 Error: Enphase: Error getting http data! (power)
These are my errors from the last 4 days
Maybe sure only one application (Domoticz) queries the Enphase, do not use two applications.
I can only speak of the native implementation as I do not use the plugin version (no reason too)
And I did not change the plugin code, so better check at the plugin author
Posted: Sunday 07 June 2026 15:22
by Gingerpale
I get 3 error messages about 2 sec apart each update interval of 2 min. Is there a clue in that? How many times per update interval is it trying to connect to Enphase or fetch data?
2026-06-07 13:53:20.590  Error: Solar Panels: Error getting http data! (check_jwt)
2026-06-07 13:53:23.952  Error: Solar Panels: Error getting http data! (check_jwt)
2026-06-07 13:53:26.012  Error: Solar Panels: Error getting http data! (check_jwt)
2026-06-07 13:55:27.994  Error: Solar Panels: Error getting http data! (check_jwt)
2026-06-07 13:55:31.691  Error: Solar Panels: Error getting http data! (check_jwt)
2026-06-07 13:55:33.775  Error: Solar Panels: Error getting http data! (check_jwt)
2026-06-07 13:57:34.610  Error: Solar Panels: Error getting http data! (login)
2026-06-07 13:57:38.029  Error: Solar Panels: Error getting http data! (check_jwt)
2026-06-07 13:57:40.138  Error: Solar Panels: Error getting http data! (check_jwt)
It can be a backend problem as well of course, but is there a way to test this?
I don't fully understand this. If I would use two applications using same token and not querying at the same time, what would be the problem?
Posted: Sunday 07 June 2026 20:02
by Arjan2019
@Gingerpale,
He means don't use 2x domoticz or 1x domoticz and homeassistant.
Make sure only 1 application is polling from the envoy
Posted: Sunday 07 June 2026 20:07
by Arjan2019
Found this
For Home assistant they needed to change the url to login
See
https://github.com/vincentwolsink/home_ ... cbdb4b09a8
Posted: Sunday 07 June 2026 21:57
by Gingerpale
Arjan2019 wrote: Sunday 07 June 2026 20:02 use two applications using same token and not querying at the same time
But why? Using two applications using exactly same token and not querying at the same time, e.g. application 1 at every xx.30 and application 2 at every xx.00, should work. In fact, it worked for me already more than 1 year...until June 5th :-)
Arjan2019 wrote: Sunday 07 June 2026 20:07 Found this
See
This is a very good find! I read it's related to the installer token after a change at Enphase backend. This might explain our issue. If it's fully understood, I hope a solution can be implemented in one of the upcoming beta's, so we can test it.
Posted: Tuesday 09 June 2026 9:24
by Gingerpale
Since a few hours, it seems to work again for me. Also reading similar messages at Github. So the issue was on Enphase backend.
Posted: Tuesday 09 June 2026 13:56
by gizmocuz
As mentioned before:
Now, go use the native implementation and be done with it... even if the plugin might work (as does windows 95), windows 11 is so much better :mrgreen:
Posted: Tuesday 09 June 2026 15:16
by edwin1234
Gingerpale is using the http version he has the same problems
So…..🤨
Posted: Tuesday 09 June 2026 16:50
by BartSr
Seems same as my solaredge problems. Dealer stopped selling solaredge and is selling enphase now.
Dealer gave me new API key and just few problems were solved. At long last I contacted solaredge directly. They also provided me with new API key. Using that one solved all problems.
