2026.2 released Error opening url API Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
pierrotori
Domoticz version: 2024.4
Post by pierrotori »
every day the system execute dz.openurl(
http://127.0.0.1:8080/json.htm?type=command&param=setactivetimerplan&ActiveTimerPlan=1
) and since the 2026.2 release i have this error : Error opening url
in fact if i test in the navigator
, no action.
if i test
 http://xxx.xxx.x.x:8080/json.htm?type=command&param=setactivetimerplan&ActiveTimerPlan=1
, it's ok
But if i put the last url in the the fonction openurl, it's always on error
remarks : my api protection is off : Allow Basic-Auth authentication over plain HTTP (API only).
Could you check please ?
Pierrotori
rpi : Raspberry Pi 2 Model B Rev 1.1 / Modele : Cortex-A7 armv7l GNU/Linux / Os Name : bullseye
Docker/Domoticz/zwave-ui/homebridge/mosquitto/wireguard
Re: 2026.2 released Error opening url API timerplan
Edit: Irrelevant...
Did you test this in browser on the Domoticz server machine?
Is It a docker environment as docker container has its own internal IP and that needs to be enabled in security settings. https://wiki.domoticz.com/Docker#IP_set ... e_gateways
Other Domoticz API calls have the same issue?
A nice one to test is with /json.htm?type=command&param=getversion as it gives different results based on authorisations etc:
https://wiki.domoticz.com/Domoticz_API/ ... z_instance
pierrotori
yes it's a docker landscape
i don't test in the browser on the domoticz, i haven't the graphical interface, but i can test with curl command
i tested the url
in the shell script on my raspberry2, but the script use curl command and it's ok
i realize a another test this evening
pierrotori
in the conatainer
root@d4730d11f3fe:/opt/domoticz# curl "http://127.0.0.1:8080/json.htm?type=command&param=getversion"
        "DomoticzUpdateURL" : "https://www.domoticz.com/download.php?channel=stable&type=release&system=linux&machine=armv7l",
        "HaveUpdate" : false,
        "Revision" : 18006,
        "SystemName" : "linux",
        "UseUpdate" : false,
        "build_time" : "2026-05-31 16:30:50",
        "db_size" : 7225344,
        "dzvents_version" : "3.1.11",
        "hash" : "f3afb08ad",
        "python_version" : "3.13.5 (main, May  5 2026, 21:05:52) [GCC 14.2.0]",
        "status" : "OK",
        "title" : "GetVersion",
        "version" : "2026.2"
root@d4730d11f3fe:/opt/domoticz# curl "http://192.168.0.6:8080/json.htm?type=command&param=getversion"
        "status" : "OK",
root@d4730d11f3fe:/opt/domoticz# curl "http://127.0.0.1:8080/json.htm?type=command&param=setactivetimerplan&ActiveTimerPlan=1"
        "status" : "ERR",
        "title" : "SetActiveTimerPlan"
root@d4730d11f3fe:/opt/domoticz# curl "http://192.168.0.6:8080/json.htm?type=command&param=setactivetimerplan&ActiveTimerPlan=1"
<html><head><title>Unauthorized</title></head><body><h1>401 Unauthorized</h1></body></html>
same error on the host
he doesn't accept the activeTimerPlan ,?!?
What if you do activate the timerplan from the gui? Do you see the same url in the developer network console (F12)?
pierrotori
i found , when you call http://127.0.0.1:8080/json.htm?type=com ... imerPlan=1 then the Timer Plan is already equal to 1, you have the error open url
i have this error since the 2026.1
Ah Ok , issue solved...
pierrotori
i check with the api getsettings and if the ActiveTimerPlan is the same of next ActiveTimerPlan , i don't send the ActiveTimerPlan
