Dashboard doesnt show right on iphone with v2026.2
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
cencen
Post by cencen »
I just upgraded to Domoticz version 2026.2, which looks great.
On my iphone however, the dashboard is not readable.
Does anybody know what the cause could be?
The dashboard shows correctly on my PC and I did not use dynamic dashboard.
gizmocuz
Re: Dashboard doesnt show right on iphone with v2026.2
Post by gizmocuz »
And you are using the default theme? You also cleared the browser cache on your iphone?
cencen
Post by cencen »
I was not using default, but element light. After switching to default it works!
I did like element light better though.
Thanks for your help!
Kimmyn
Target OS: OS X
Post by Kimmyn »
I encountered a similar issue with some custom interfaces after updates. Non-native themes can sometimes have display problems depending on the browser or mobile resolution. It's a bit like a site redesign; you often need to rethink mobile adaptation and ensure everything remains consistent across screens. I'm glad switching back to the default theme fixed the problem, even though Element Light is indeed more visually appealing.
Thanks for the feedback; it could help other users facing the same issue.
