dzVents stops
Posted: Saturday 16 May 2026 15:37
by knasson
i am on domoticz v2026.1 (build 17920)
dzVents 3.1.11
why dzVents engine stops ?
No warnings
It is very ennoying because you expect the scripts running and not at all.
how to check easily the dzVents working?
The scipts are running for a long time and one day tonanother it stops unexpectedly.
as an example the script used
    active = true,
        devices = { 'Garage_ouvert' }
    logging = {
        level = domoticz.LOG_INFO,
        marker = 'GarageAutoClose'
        local tempo = 60 -- secondes
        local contact = domoticz.devices('Garage_ouvert')
        local porte   = domoticz.devices('Porte_Garage')
        -- PORTE OUVERTE
        if contact.state == 'On' then
            domoticz.log('Garage_ouvert -> fermeture dans '..tempo..' sec', domoticz.LOG_INFO)
            -- évite les doublons si le contact se réactualise
            porte.cancelQueuedCommands()
            -- programme la fermeture
            porte.switchOn().afterSec(tempo)
        -- PORTE REFERMEE
        if contact.state == 'Off' then
            domoticz.log('Porte refermee -> annulation fermeture auto', domoticz.LOG_INFO)
            -- annule la fermeture programmée
Re: dzVents stops
Posted: Sunday 17 May 2026 8:10
by gizmocuz
dzVents should always run, unless you make a endless loop.
But to check, just create a small timer that runs every minute and logs "Hello World"
The device "Garage_ouvert", is updating?
Start with a dummy switch that you can click, and later replace that for the real switch
Re: dzVents stops
Posted: Sunday 17 May 2026 13:17
by knasson
Yes for checking manually i push a switch and look at the result in the log.
but i want to be sure the dzVents script will work without any checking.
My garage door is open manually and i want to be sure it will close when i leave my house.
what do you mean by "Garage_ouvert" updating"?
When i start for the first time in the morning the device "Garage_ouvert" is "Off" when the door is open it moves to "On" until the scripts commands to close the door (after 120 s approx) and the device "Garage_ouvert" move to "Off" after 1 sec aprox.
Re: dzVents stops
Posted: Wednesday 20 May 2026 16:57
by knasson
i need to make this script reliable.
this work all the day after rebooting.
i can't reboot my system every morning.
Most of time dzVents is stopped
what will be the tric to restart dzVents without rebooting or more what will be the tric to avoid it stopping ? :D
Re: dzVents stops
Posted: Wednesday 20 May 2026 19:12
by madpatrick
it is possible the scripts comes in a loop because it is waiting for 60 sec and when command come in
try this
    active = true,
    logging = {
        local tempo = 60 -- seconds
        -- DOOR OPEN
            domoticz.log('Garage_ouvert -> closing in '..tempo..' seconds', domoticz.LOG_INFO)
            -- avoid duplicates if the contact refreshes again
            -- schedule closing
        -- DOOR CLOSED
        elseif contact.state == 'Off' then
            domoticz.log('Door closed -> auto close cancelled', domoticz.LOG_INFO)
            -- cancel scheduled closing
Re: dzVents stops
Posted: Friday 22 May 2026 9:28
by knasson
i modified yesterday as recommanded and this morning it is always running i will observe that during a while to see more..
Re: dzVents stops
Posted: Saturday 23 May 2026 20:54
by knasson
madpatrick wrote: Wednesday 20 May 2026 19:12 it is possible the scripts comes in a loop because it is waiting for 60 sec and when command come in
try this
    active = true,
    logging = {
        -- DOOR OPEN
            -- schedule closing
        -- DOOR CLOSED
Thank you it is ok ...but what is this magical tric? Explain more please....
Re: dzVents stops
Posted: Sunday 24 May 2026 8:32
by madpatrick
he real potential problem
This line:
is the dangerous part.
Why?
Because this does not actually mean:
"close the garage"
What it really means is:
"set Porte_Garage to ON after 60 seconds"
With many garage door controllers, ON is simply a pulse/toggle command.
So:
open → pulse = close
closed → pulse = open
That means the following scenario can happen:
The garage door opens
The timer starts
Someone closes the garage manually
After 60 seconds the script still executes switchOn()
The garage door opens again
Re: dzVents stops  [Solved]
Posted: Sunday 24 May 2026 17:38
by knasson
Any way since the change no more stopping , thank you so much
