This guide shows how to integrate a Samsung SmartThings washing machine with Domoticz using MQTT and SmartThings CLI on Raspberry Pi/Linux.
The setup provides:
* Washer status
* Wash program detection
* Remaining time
* Progress percentage
* Power consumption
* Total energy usage
* MQTT integration
* Automatic background service
* Auto start after reboot
Tested with Samsung WW80CGC0EDA/ELE and Raspberry Pi OS.
# Requirements
* Raspberry Pi / Linux server
* Domoticz installed
* Internet connection
* Samsung washer connected to SmartThings
* MQTT enabled in Domoticz
* SmartThings account
# Credits
Integration created using:
* SmartThings CLI
* Mosquitto MQTT
* Bash scripting
* Domoticz MQTT JSON API
This guide is intended for Domoticz forum users and home automation enthusiasts.
This guide explains how to integrate a Samsung washing machine from SmartThings into Domoticz using MQTT on Raspberry Pi/Linux.
Features:
* Washer status
* Program name
* Remaining time
* Progress %
* Power consumption
* Energy monitoring
* Automatic updates
* Auto-start service
# 1. Install Node.js and npm
Check if already installed:
node -v
npm -v
sudo apt update
sudo apt install nodejs npm -y
# 2. Install SmartThings CLI
Install SmartThings CLI globally:
sudo npm install -g @smartthings/cli
smartthings --version
# 3. Login to SmartThings
Run:
smartthings login
# 4. Find Your Washer Device ID
List SmartThings devices:
smartthings devices
Name Device ID
Samsung Washer xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
# 5. Install jq
sudo apt install jq -y
# 6. Install MQTT Broker
Install Mosquitto MQTT broker and clients:
sudo apt install mosquitto mosquitto-clients -y
sudo systemctl enable mosquitto
sudo systemctl start mosquitto
# 7. Create the Washer Script
Create the script file:
nano /home/pi/washer.sh
#!/bin/bash
DEVICE_ID="YOUR DEVICE ID"
BROKER="localhost"
STATUS_IDX=1992
JOB_IDX=1993
PROGRESS_IDX=1994
SWITCH_IDX=1995
PRG_IDX=1998
RMTIME_IDX=2014
ELECTRIC_IDX=2018
#ENERGY_FILE="/home/pi/scripts/washer_energy.txt"
LAST=""
while true
do
DATA=$(smartthings devices:status $DEVICE_ID --json)
STATUS=$(echo "$DATA" | jq -r '.components.main["samsungce.washerOperatingState"].operatingState.value')
JOB=$(echo "$DATA" | jq -r '.components.main["samsungce.washerOperatingState"].washerJobState.value')
PROGRESS=$(echo "$DATA" | jq -r '.components.main["samsungce.washerOperatingState"].progress.value // 0')
RMTIME=$(echo "$DATA" | jq -r '.components.main["samsungce.washerOperatingState"].remainingTimeStr.value // 0')
SW=$(echo "$DATA" | jq -r '.components.main["samsungce.switch"].switch.value')
PRG=$(echo "$DATA" |jq -r '.components.main["custom.supportedOptions"].course.value // "unknown"')
ENERGY=$(echo "$DATA" | jq -r '.components.main.powerConsumptionReport.powerConsumption.value.energy // 0')
POWER=$(echo "$DATA" | jq -r '.components.main.powerConsumptionReport.powerConsumption.value.power // 0')
# DELTAENERGY=$(echo "$DATA" | jq -r '.components.main.powerConsumptionReport.powerConsumption.value.deltaEnergy')
[ -z "$POWER" ] && POWER=0
[ -z "$ENERGY" ] && ENERGY=0
CURRENT="$STATUS|$JOB|$PROGRESS|$SW|$PRG|$RMTIME"
CURRENT2="$ENERGY|$POWER"
if [ "$CURRENT" != "$LAST" ]; then
echo "Status: $CURRENT|$CURRENT2"
# 📝 STATUS (TEXT)
mosquitto_pub -h $BROKER -t domoticz/in -m "{
\"idx\": $STATUS_IDX,
\"nvalue\": 0,
\"svalue\": \"$STATUS\"
# 🧺 JOB STATE (TEXT)
\"idx\": $JOB_IDX,
\"nvalue\": 0,
\"svalue\": \"$JOB\"
# 🧺 REMAINING TIME (TEXT)
# Convert HH:MM to minutes
if [[ "$RMTIME" =~ ^([0-9]{2}):([0-9]{2})$ ]]; then
HOURS=${BASH_REMATCH[1]}
MINS=${BASH_REMATCH[2]}
TOTAL_MIN=$((10#$HOURS * 60 + 10#$MINS))
TOTAL_MIN=0
fi
if [ "$STATUS" = "running" ] || [ "$STATUS" = "paused" ]; then
RT=$TOTAL_MIN
RT=0
fi
\"idx\": $RMTIME_IDX,
\"nvalue\": 0,
\"svalue\": \"$RT\"
# 📊 PROGRESS (%)
\"idx\": $PROGRESS_IDX,
\"nvalue\": 0,
\"svalue\": \"$PROGRESS\"
# ⚡ PROGRAM
Pname="UNKNOWN ($PRG)"
case "$PRG" in
"1C") Pname="ECO 40-60" ;;
"1B") Pname="COTTON" ;;
"25") Pname="SYNTHETICS" ;;
"20") Pname="HYGIENE STEAM" ;;
"08") Pname="RINSE + SPIN" ;;
"74") Pname="DRUM CLEAN" ;;
"87") Pname="DOWNLOADED" ;;
"06") Pname="BEDDING" ;;
"7F") Pname="WOOL/DELICATES" ;;
"65") Pname="COLOURS" ;;
"8F") Pname="INTENSE COLD" ;;
"96") Pname="LESS MICROFIBER" ;;
"34") Pname="MIXED LOAD" ;;
"A0") Pname="QUICK WASH 15min" ;;
esac
\"idx\": $PRG_IDX,
\"nvalue\": 0,
\"svalue\": \"$Pname\"
# ⚡ SWITCH (ON/OFF)
if [ "$SW" = "on" ]; then
N=1
N=0
fi
\"idx\": $SWITCH_IDX,
\"nvalue\": $N,
\"svalue\": \"\"
# ⚡ CONSUMPTION
#PREV_ENERGY=$(cat $ENERGY_FILE 2>/dev/null || echo "0")
#DELTA_ENERGY=$(echo "scale=3; $ENERGY - $PREV_ENERGY" | bc)
# [ -z "$DELTA_ENERGY" ] && DELTA_ENERGY=0
# ако е негативно (reset), стави 0
#if (( $(echo "$DELTA_ENERGY < 0" | bc -l) )); then
#DELTA_ENERGY=0
#fi
# echo "$ENERGY" > $ENERGY_FILE
\"idx\": $ELECTRIC_IDX,
\"nvalue\": 0,
\"svalue\": \"$POWER;$ENERGY\"
LAST="$CURRENT"
fi
if [ "$SW" = "off" ]; then
SLEEP_TIME=900 # 20 минути 1200
elif [ "$SW" = "on" ]; then
SLEEP_TIME=60 # 1 минута
SLEEP_TIME=120 # fallback
fi
echo "Next check in $SLEEP_TIME sec"
#echo "$POWER | $ENERGY"
sleep $SLEEP_TIME
done
# 8. Make Script Executable
chmod +x /home/pi/washer.sh
# 9. Test the Script
Run manually:
/home/pi/washer.sh
Status: running|spin|45|on
Next check in 60 sec
# 10. Create Virtual Devices in Domoticz
Open:
Setup → Hardware
* Dummy Hardware
# 11. Create Virtual Sensors
## STATUS
Type:
* Text
## JOB STATE
Type:
* Text
## PROGRAM
Type:
* Text
## REMAINING TIME
Type:
* Custom Sensor
Unit:
min
## PROGRESS
Type:
* Percentage
## SWITCH
Type:
* Switch
## POWER + ENERGY
Type:
* Electric (Instant + Counter)
IMPORTANT:
* Data source must be:
From Device
# 12. Get Device IDX Values
Open:
Setup → Devices
Example:
1993
1994
STATUS_IDX=1992
JOB_IDX=1993
# 13. MQTT Test
Test Domoticz MQTT input:
mosquitto_pub -h localhost -t domoticz/in -m '{"idx":1992,"nvalue":0,"svalue":"running"}'
# 14. Create systemd Service
Create service file:
sudo nano /etc/systemd/system/washer.service
[Unit]
Description=Samsung Washer Monitor
After=network.target
[Service]
ExecStart=/home/pi/washer.sh
Restart=always
User=pi
[Install]
WantedBy=multi-user.target
# 15. Enable and Start the Service
Reload systemd:
sudo systemctl daemon-reload
sudo systemctl enable washer.service
sudo systemctl start washer.service
# 16. Check Service Status
Check status:
sudo systemctl status washer.service
journalctl -u washer.service -f
# 17. Restart the Service
sudo systemctl restart washer.service
# 18. Stop the Service
sudo systemctl stop washer.service
# 19. Verify Auto Start
Check if enabled:
systemctl is-enabled washer.service
# 20. Check SmartThings JSON Data
smartthings devices:status DEVICE_ID --json
# 21. Useful MQTT Debugging Commands
Monitor MQTT messages:
mosquitto_sub -v -t domoticz/in
systemctl is-active washer.service
# 22. Final Result
After completing the setup, Domoticz will display:
* Washer ON/OFF state
* Current washer status
* Current wash cycle
* Remaining time in minutes
* Instant power usage
* Historical energy graphs
* Automatic updates via MQTT
* Automatic startup after reboot
The washer integration runs fully automatically in the background using systemd.
# Troubleshooting
## MQTT messages not updating
Check Mosquitto service:
sudo systemctl status mosquitto
## SmartThings CLI not working
Re-login:
smartthings login
smartthings devices
## Washer service not starting
Check logs:
## Domoticz energy graph incorrect
Use:
From Device
* Computed
* Incremental Counter
* RFXMeter
# Notes
* ENERGY value must be total cumulative energy from SmartThings.
* POWER value must be current live power in Watts.
* Domoticz expects:
POWER;TOTAL_ENERGY
250;1.523
# Forum Notes
This setup uses polling through SmartThings CLI.
Recommended polling intervals:
| Washer State | Polling Time |
| OFF | 900 sec |
| ON / Running | 60 sec |
| Fallback | 120 sec |
This minimizes API calls while still providing responsive updates.
# End of Guide
You now have:
* Live washer status
* Active wash program
* Remaining time
* Power consumption monitoring
* Energy history graphs
* Automatic MQTT updates
* Auto-start after reboot
fully integrated into Domoticz.
