Somfy plugin is almost every 15 minutes communicating
Posted: Monday 27 April 2026 19:45
by Rik60
The Somfy plugin is almost every 15 minutes communicating with the somfy box. Only during day-mode while there are no device actions. There are no errors, the log file can grow very big if not monitored. Is it nessesary to communicate every 15 minutes and log this?
Re: Somfy plugin is almost every 15 minutes communicating
Posted: Monday 27 April 2026 20:01
by madpatrick
Have you checked the readme ?
You can setup your own interval timing
Day/Night polling
Separate intervals for day and night, configurable via config.txt (DAY_INTERVAL / NIGHT_INTERVAL).
Temporary fast polling after commands for faster status updates, configurable via config.txt (TEMP_DELAY / TEMP_TIME).
I've made version 5.3.1 without the somfy.log
No need any more for this
Posted: Monday 27 April 2026 23:55
by Rik60
I have checked the readme. I think it's not a config setting. But thanks for the update for the logging setting
Posted: Wednesday 29 April 2026 10:42
by Rik60
Thanks for the update, indeed there is no somfy logging anymore. But what is changed? Just the version number? I am asking because i am trying to understand the changes, learning Python...
Posted: Wednesday 29 April 2026 10:51
by madpatrick
You can see all chanhed in the code on GIT easlily
https://github.com/MadPatrick/domoticz_ ... ts/master/
And click on the commit
2026-04-29 10_51_17-.png (71.35 KiB) Viewed 24876 times
Posted: Wednesday 29 April 2026 12:03
by Rik60
thanks, now it's clear to me :D, but don't you have to remove those lines in the other files?
