Multi-threaded plugins problem Topic is solved
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
mgugu
Pi2/Trixie - Domoticz: latest beta
I tested this multi-threaded plugin example :https://github.com/domoticz/domoticz/bl ... hreaded.py
Encountered issues:
- Domoticz hangs undefinitely when I click on update - Restarting domoticz service is very long
Other multithreaded plugins I tested have same kind of issues.
Are there some restrictions in using multi-threaded plugins ?
Encountered issues:
- jvdz
- Domoticz version: 4.107
Re: Multi-threaded plugins problem
Do you get any messages in the log when you test as the OnStop() function should show you whether it is waiting for threads to finish?
mgugu
Yes, on another multi-threaded plugin (Domoticz universal GPIO) I get following messages after service restart or hardware update:
And the still running thread is Mainthread
2026-04-25 16:14:58.240 GPIO: GPIO event_loop exited
2026-04-25 16:14:58.242 Error: GPIO: Plugin has 1 Python threads still running.
2026-04-25 16:14:59.243 Error: GPIO: Plugin has 1 Python threads still running.
2026-04-25 16:15:00.244 Error: GPIO: Plugin has 1 Python threads still running.
2026-04-25 16:15:01.244 Error: GPIO: Plugin has 1 Python threads still running.
2026-04-25 16:15:02.245 Error: GPIO: Plugin has 1 Python threads still running.
2026-04-25 16:15:03.245 Error: GPIO: Plugin has 1 Python threads still running.
2026-04-25 16:15:04.246 Error: GPIO: Plugin has 1 Python threads still running.
2026-04-25 16:15:05.247 Error: GPIO: Plugin has 1 Python threads still running.
2026-04-25 16:15:06.247 Error: GPIO: Plugin has 1 Python threads still running.
2026-04-25 16:15:07.248 Error: GPIO: Plugin has 1 Python threads still running.
2026-04-25 16:15:08.248 Error: GPIO: Plugin has 1 Python threads still running.
2026-04-25 16:15:08.249 Error: GPIO: Plugin has 1 Python threads still running.
2026-04-25 16:15:08.249 Error: GPIO: Abandoning wait for Plugin thread shutdown, hang or crash may result.- jvdz
The example plugin you linked does tell the thread to close by supplying a None into the messagequeue: self.messageQueue.put(None), so the thread knowns it needs to stop:
Have you done something similar?
Message = self.messageQueue.get(block=True)
if Message is None:
Domoticz.Debug("Exiting message handler")
self.messageQueue.task_done()
break
Rik60
- Domoticz version: 2026.3
Can you check the plugin code:mgugu wrote: Saturday 25 April 2026 16:21 Yes, on another multi-threaded plugin (Domoticz universal GPIO) I get following messages after service restart or hardware update:And the still running thread is MainthreadCode: Select all
2026-04-25 16:14:58.240 GPIO: GPIO event_loop exited 2026-04-25 16:14:58.242 Error: GPIO: Plugin has 1 Python threads still running. 2026-04-25 16:14:59.243 Error: GPIO: Plugin has 1 Python threads still running. 2026-04-25 16:15:00.244 Error: GPIO: Plugin has 1 Python threads still running. 2026-04-25 16:15:01.244 Error: GPIO: Plugin has 1 Python threads still running. 2026-04-25 16:15:02.245 Error: GPIO: Plugin has 1 Python threads still running. 2026-04-25 16:15:03.245 Error: GPIO: Plugin has 1 Python threads still running. 2026-04-25 16:15:04.246 Error: GPIO: Plugin has 1 Python threads still running. 2026-04-25 16:15:05.247 Error: GPIO: Plugin has 1 Python threads still running. 2026-04-25 16:15:06.247 Error: GPIO: Plugin has 1 Python threads still running. 2026-04-25 16:15:07.248 Error: GPIO: Plugin has 1 Python threads still running. 2026-04-25 16:15:08.248 Error: GPIO: Plugin has 1 Python threads still running. 2026-04-25 16:15:08.249 Error: GPIO: Plugin has 1 Python threads still running. 2026-04-25 16:15:08.249 Error: GPIO: Abandoning wait for Plugin thread shutdown, hang or crash may result.
if self.request.wait_edge_events(5):
copilot thinks that this is the problem
mgugu
@jvdz, here is the multi-threaded GPIO plugin provided by Rik60, it provides error messages at restart while Multi-threaded Plugin example hangs
@Rik60, changing self.request.wait_edge_events(5) to (0.2) does not change anything.
I submitted the problem to Anthropic AI (also to improve inputs management) and he told me that the plugin is properly coded and the problem comes likely from domoticz mainthread management.
- Domoticz-Universal-GPIO.zip
- (2.9 KiB) Downloaded 97 times
Rik60
Perhaps it isn't the this plugin as you wrote. But the change worked for me. Btw, i have seen this error also when other plugin is stopping. Zigbee 4 Domoticz is also showing this error when Domoticz is restarting but i didn't pay attention to it.
- gizmocuz
@Rik60, yes Zigbee4domoticz has know issues, and are solved when using a new python version, but that is not officially supported
- gizmocuz
Should be solved when using the latest docker compose beta image (upgraded to python 3.13)
