how to get zwave-js-ui menu available in domoticz
BartSr
Domoticz version: V2024.7
Post by BartSr »
Hi years ago I managed to get a menu option so I openened from domoticz zwave-js-ui.
Since domoticz is running in docker compose my attempts fail.
I followed wiki:
Optional you can add the frontend User interface of Zwave-JS-UI as a custom menu in Domoticz.
Make a file Zwave-JS-UI.html in domoticz/www/templates
Contents
<IFRAME SRC="http://IPAddress:8091/" height="800" width="100%"></IFRAME>
Rename IPAddress to the real IP address of your domoticz server. Also change the port of the frontend if changed in setup.
Restart Domoticz and you will have another Zwave-JS-UI entry in custom menu.
But I cannot get this to work. Do I miss something?
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Re: how to get zwave-js-ui menu available in domoticz
Change the docker compose yml as indicated in the wiki: https://wiki.domoticz.com/Docker#Custom_templates
BartSr
Post by BartSr »
Thanks Walter. This works but unclear why. But that's just me.
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
That is how docker works with external managed volumes...
