Somfy updating through Git Pull doesn't work Topic is solved
Rik60
Post by Rik60 »
I am trying to update the Somfy plugin with 'git pull' but receive the message back:
Fatal: Not a git repository (or any of the parrent directories): .git
I was still on a test plugin but wanted to go back to the master. I installed the master by downloading the zip file and copied the files into the plugin folder. The plugin is running now but if i try 'git pull' i still keeping the same message insteat that the plugin is up to date.
I tried another plugin (Z4D) to update through git pull, that was working (already up to date).
madpatrick
Domoticz version: 2026.1
Re: Somfy updating through Git Pull doesn't work
Post by madpatrick »
Easiest way is to remove the directory and make a new pull
git clone https://github.com/MadPatrick/domoticz_somfy
Rik60
Post by Rik60 »
Deleted the plugin folder and re-installed the plugin using:
Is was:
git clone https://github.com/MadPatrick/somfy
I know now why it didn't work: The name of the plugin folder is changed, it was somfy first, now it is domoticz_somfy
The readme.md is not up to date, this has to be updated.
madpatrick
readme is now adjusted.
Rik60
Post by Rik60 »
I think that not only line 121 has to be changed...
madpatrick
Rik60 wrote: Tuesday 14 April 2026 17:19 I think that not only line 121 has to be changed...
You can always suggest a PR in Git ;)
