Page 1 of 7
🌙 Nightglass Theme (WIP)
Posted: Sunday 12 April 2026 17:01
by galadril
This is very much a work in progress theme.
Iβm experimenting with styling approaches, icon mapping, and improving the overall UX without breaking existing functionality.
More info and demo here
https://galadril.github.io/Domoticz-Nightglass-Theme/
Issues / feature requests:
Please register them here
https://github.com/galadril/Domoticz-Ni ... eme/issues
Feedback & Ideas
Iβd love to get feedback, ideas, or suggestions from you all!
Re: 🌙 Nightglass Theme (WIP)
Posted: Sunday 12 April 2026 19:20
by madpatrick
Cool.
Just tried it and works nice
Posted: Monday 13 April 2026 12:20
by waltervl
Thanks, going to check this out very soon.
Posted: Monday 13 April 2026 17:42
by galadril
Great. I did some more fixes and visual adjustments today
Added:
Add temperature-, weather-, and sensor-driven accent coloring to device cards based on their readings.
Add sparkline micro-charts as subtle card background visualizations for sensor history.
Add a keyboard-driven search overlay and numeric shortcuts to quickly navigate and locate device cards.
Add 3D tilt interactions on cards and visual flashes when device state changes.
Enhancements/Fixes:
Mark stale devices based on last-update timestamps with a subtle pulsing indicator dot.
Enhance device icons with context-appropriate animations while active (spin, flicker, pulse).
Posted: Monday 13 April 2026 18:27
by imautohuttraeger
Great! Really appreciate it.
Shall the extra line for type indication, e.g.
"Type: Color Switch, RGBWW, Dimmer"
remain this way? If not, I would prefer to have it back beside the icon and the status (e.g. "66%") back beside the name. So the hight of the tile would be smaller again.
Please advice if such a feedback might be needless in this early stage.
Posted: Monday 13 April 2026 21:09
by galadril
imautohuttraeger wrote: Monday 13 April 2026 18:27
Yes thats fine/good.
I do need to weight in my own opinions ofcourse as well, as theme/style is mostly a matter of taste i guess
But thanks!
Posted: Tuesday 14 April 2026 0:32
by waltervl
I like it. Some feedback:
- I see some question marks before my temperature readings. Also minus sign where it should be no sign (or +)
- The temperature graph in the widget is nice but should be highlighted more for better visibility
- That graph in the background of the widget should also be shown when you use the widget in the new dashboard functionality. It currently does not.
- Schermafbeelding 2026-04-14 002811.png (54.52 KiB) Viewed 188063 times
Posted: Tuesday 14 April 2026 8:52
by galadril
waltervl wrote: Tuesday 14 April 2026 0:32
That icon tries to show a trend, see
https://github.com/user-attachments/ass ... 9432486054
so it shows going up, or the flat line means stable, or going down (red icon).
Question mark, then it can determine.. but maybe this was not clear enough or does not work good enough
I've just improved this a bit on the current/latest version, please update
Maybe on focus with mouse make the graph a bit more visible?
Because i was playing with this and it became quite overwelming/busy as well. WDYT
With what widget?
Because it was working on the favorites new dashboard widget
https://github.com/user-attachments/ass ... cf632b5376
Other then that, ive pushed a new version with various changes i worked on last night.
Also revamped the visuals of the menu/submenu's a bit
Posted: Tuesday 14 April 2026 13:44
by JayDotR
very nice one !
Posted: Tuesday 14 April 2026 15:34
by imautohuttraeger
Icon to change dark mode and light mode is overlapping with general settings gear symbol (see screenshots from cellphone with android chrome).
Posted: Tuesday 14 April 2026 19:51
by HansieNL
I got the same problem as @imautohuttraeger , but then with my iPad
And the custom menu is behind the rest if selected, so can't be really used.
- Schermafbeelding 2026-04-14 om 19.22.22.jpg (293.43 KiB) Viewed 187955 times
Hope this can be fixed so theme can be really used on iPad.
Thank you.
Posted: Wednesday 15 April 2026 0:22
by waltervl
galadril wrote: Tuesday 14 April 2026 8:52
Thanks, all working correctly now!
The hoover mouse over the widget to see the backround graphs better is not it for me.
The complete hoover function could be deleted for me..... Especially when used on a tablet.
Posted: Wednesday 15 April 2026 12:58
by imautohuttraeger
BTW: I do like the red dot in the top right corner of a device if there is a time out state.
Posted: Wednesday 15 April 2026 17:09
by domcars0
Hello. I just tried out this new theme, and I have to say I really like it. Itβs a superb piece of work. Since the Aurora theme no longer works on the latest versions of Domoticz, the Nightglass Theme seems like a very strong contender to replace it. I hope Nightglass has as long a lifespan as Aurora... or even longer
! Thank you very much. Iβll be sure to provide feedback if needed.
Posted: Wednesday 15 April 2026 18:11
by domcars0
Just found a small bug in the custom.js
// Base path: strips the hash and trailing filename, keeps the directory
// e.g. "
http://server:8080/" β ""
http://server/domoticz/" β "domoticz/"
But in fact, I think it must be
http://server/domoticz/" β "/domoticz/"
On my server with 2 URL access ( http:// domoticz.local:8080 and http:// myserver.mydomain/domoticz ) the widget highcharts backgrounds works well with the domoticz.local URL, but does not work with the myserver.mydomain/domoticz URL if the BASE function returns "domoticz/" but works well if it returns "/domoticz/"
So I think that in the BASE function
var BASE = (function () {
// var p = window.location.pathname.replace(/\/[^/]*$/, '/').replace(/^\//, '');
should be enough ?
Posted: Wednesday 15 April 2026 18:25
by galadril
imautohuttraeger wrote: Wednesday 15 April 2026 12:58
Cool Thanks
Posted: Wednesday 15 April 2026 20:16
by galadril
HansieNL wrote: Tuesday 14 April 2026 19:51
imautohuttraeger wrote: Tuesday 14 April 2026 15:34
This should be better on the latest version
Posted: Wednesday 15 April 2026 20:20
by imautohuttraeger
Yes, confirm it is perfectly fixed. Thx!
Posted: Wednesday 15 April 2026 21:05
by galadril
It would be verify helpful if we create the issues/feature requests here btw:
Posted: Friday 17 April 2026 20:51
by galadril
