Fahrenheit to Celcius (or C to F) conversion
palnic
- Domoticz version: V3.8153
I have five Tuya TS601 thermostat. They are measure temperature in Celsius. In Domoticz settings I set Temperature display in Fahrenheit. Temperature in Fahrenheit displays as a decimal, more sense to display it as an integer. When I adjust set point, I have to enter temperature in Celsius, or I am getting error
- C_toF_1.jpg (58.68 KiB) Viewed 16415 times
- C_toF.jpg (26.29 KiB) Viewed 16415 times
- gizmocuz
Re: Fahrenheit to Celcius (or C to F) conversion
When you press 'Edit' on the Setpoint, what is specified for the min/max range? You need to change this to Fahrenheit as well.
palnic
The min and max values come fromhttps://www.zigbee2mqtt.io/devices/TS06 ... ostat.html and I can't change to Fahrenheit
