Domoticz errors Rooted Toon Topic is solved
sekeris82
Post by sekeris82 »
I am running Domoticz 2025-2 beta build 17366.
When I put my rooted Toon (V2) on vacation The Toon starts sending error messages.
IndexError: list index out of range
2026-04-09 17:13:00.213 Error: Toon thermostaat: Call to function 'onMessage' failed, exception details:
2026-04-09 17:13:00.213 Error: Toon thermostaat: Traceback (most recent call last):
2026-04-09 17:13:00.213 Error: Toon thermostaat: File "/opt/domoticz/userdata/plugins/domoticz_toon/plugin.py", line 660, in onMessage
2026-04-09 17:13:00.213 Error: Toon thermostaat: _plugin.onMessage(Connection, Data)
2026-04-09 17:13:00.213 Error: Toon thermostaat: File "/opt/domoticz/userdata/plugins/domoticz_toon/plugin.py", line 539, in onMessage
2026-04-09 17:13:00.213 Error: Toon thermostaat: self.onMessageThermostatInfo(Connection, Response)
2026-04-09 17:13:00.213 Error: Toon thermostaat: File "/opt/domoticz/userdata/plugins/domoticz_toon/plugin.py", line 312, in onMessageThermostatInfo
2026-04-09 17:13:00.213 Error: Toon thermostaat: UpdateDevice(Unit=autoProgram, nValue=0, sValue=programStates[programState])
As soon as i return to normal mode everything works fine again without error messages.
I don't know whether it is a Toon bug or a Domoticz bug, maybe this is the wrong forum for this question.
Kind regards: Bastel-Opa
gizmocuz
Re: Domoticz errors Rooted Toon
Post by gizmocuz »
First, you are using a very old version of Domoticz, but this has nothing todo with Domoticz.
You have to go to the github page of the Domoticz Python domoticz_toon plugin
madpatrick
Domoticz version: 2026.1
Post by madpatrick »
The vacation mode was indeed missing
I've pushed a new version 2.7.3
You need to remove the Switch "Auto Program" and then restart the plugin which will add the switch with vacation button
Or add "Vacation" at level 40 to the Switch manually
