Graph of used Solar Energy
jslegers
Domoticz version: 2026.2
Post by jslegers »
Is it possible to create an extra graph that shows how many power is used from the solar panels. We see the total generation. We also see the total returned energy. So if we can have a nice graph of those two values subtracted.
John
gizmocuz
Re: Graph of used Solar Energy
Post by gizmocuz »
There are two ways you could implement this.
- Write a dzVents script (see below, not tested!)
- Write a custom template file to display this (there are examples in the www/templates folder)
-- Solar Self-Consumption Calculator
-- Shows how much solar energy was actually used in the house
-- Formula: Self-Consumed = Solar Generation - Returned to Grid
-- SETUP REQUIRED:
--   1. In Domoticz: Setup > Hardware > add "Dummy" hardware (if not present)
--   2. Create a virtual sensor: type "Electric (Instant+Counter)" — note its idx
--   3. Fill in the three idx values below
local IDX_GENERATION    = 0   -- idx of your solar generation device (kWh counter)
local IDX_RETURN        = 0   -- idx of your return-to-grid device (kWh counter)
local IDX_SELF_CONSUMED = 0   -- idx of the new virtual kWh device you just created
        devices = { IDX_GENERATION, IDX_RETURN },
        timer   = { 'every 5 minutes' },
    logging = {
        level  = domoticz.LOG_INFO,
        marker = 'Solar Self-Consumption',
        local gen  = domoticz.devices(IDX_GENERATION)
        local ret  = domoticz.devices(IDX_RETURN)
        local virt = domoticz.devices(IDX_SELF_CONSUMED)
        if not gen or not ret or not virt then
            domoticz.log('One or more device idx values are not configured correctly', domoticz.LOG_ERROR)
            return
        -- Current power in Watt (clamp to 0 — can't be negative)
        local power_w = math.max(0, gen.usage - ret.usage)
        -- Cumulative counter in kWh (clamp to 0)
        -- WhTotal is in Wh, updateElectricity expects kWh for the counter
        local energy_kwh = math.max(0, (gen.WhTotal - ret.WhTotal) / 1000)
        domoticz.log(string.format(
            'Generation: %.0f W / %.2f kWh  |  Return: %.0f W / %.2f kWh  |  Self-consumed: %.0f W / %.2f kWh',
            gen.usage, gen.WhTotal / 1000,
            ret.usage, ret.WhTotal / 1000,
            power_w, energy_kwh
        virt.updateElectricity(power_w, energy_kwh)
    end,
jslegers
Post by jslegers »
Thanks for the heads up.
I needed some assistance from Claude AI to fix the script but it works. Will test it for a couple of days.
Updated script.
local IDX_GENERATION    = 49  -- GoodWe Inverter - Today's Generation (General/kWh)
local IDX_P1            = 1   -- P1 Smart Meter - Power (P1 Smart Meter/Energy)
local IDX_SELF_CONSUMED = 56  -- Virtual kWh device for self-consumption
        devices = { IDX_GENERATION, IDX_P1 },
    logging = {
        local p1   = domoticz.devices(IDX_P1)
        if not gen or not p1 or not virt then
            return
        -- Current power: generation minus what's being returned to grid
        local power_w = math.max(0, gen.WhActual - p1.usageDelivered)
        -- Cumulative today: kWh generated minus kWh returned today
        local energy_kwh = math.max(0, gen.WhTotal / 1000 - p1.counterDeliveredToday)
            'Generation: %.0f W / %.3f kWh  |  Return: %.0f W / %.3f kWh  |  Self-consumed: %.0f W / %.3f kWh',
            gen.WhActual, gen.WhTotal / 1000,
            p1.usageDelivered, p1.counterDeliveredToday,
            power_w, energy_kwh
    end,
jslegers
Post by jslegers »
Small update but still having a small issue. After quite some sessions with claude ai because I had some issues with my previous script I came up with the following script :
local IDX_GOODWE        = 50  -- GoodWe Inverter Solar (General/kWh)
local function parseKwh(val)
    if type(val) == 'number' then return val end
    return tonumber(tostring(val):match('[%d%.]+')) or 0
        timer = { 'every 1 minutes' },
    logging = {
        local gen  = domoticz.devices(IDX_GOODWE)
            return
        local gen_kwh  = parseKwh(gen.counterToday)
        local ret_kwh  = parseKwh(p1.counterDeliveredToday)
        local self_kwh = math.max(0, gen_kwh - ret_kwh)
            'Generation today: %.3f kWh  |  Returned today: %.3f kWh  |  Self-consumed: %.3f kWh',
            gen_kwh, ret_kwh, self_kwh
        ), domoticz.LOG_INFO)
        virt.updateElectricity(0, self_kwh)
    end,
I have set it to 1 minute to test. In the log I see the following :
2026-04-30 12:51:00.777  dzVents: Solar Self-Consumption: Generation today: 10.000 kWh  |  Returned today: 8.313 kWh  |  Self-consumed: 1.687 kWh
So looks like the script is working only it looks like it is not updating the dummy device the Today counter.
What am I doing wrong I don't get it.
You are missing a factor 1000 as a general kWh device needs its value in Wh, not kWh.
But this general kWh device also need this Wh value to be a running increasing total counter, not a daily resetting to 0 value.
You better change it to a custom sensor with kWh value.
Edit: Or at 23.59 hours request the current total counter value and use that as a base to start the new day (total+(self_kwh*1000))
jslegers
Post by jslegers »
waltervl wrote: Thursday 30 April 2026 13:13 You are missing a factor 1000 as a general kWh device needs its value in Wh, not kWh.
Thanks Walter for the answer. I will try it tonight.
So I need to change the line virt.updateElectricity(0, self_kwh) with virt.updateElectricity(0, self_kwh*1000)
My goal is indeed to start this script at 23:55.
I would trigger the script on every change of the goodwe inverter, not every minute (is also not needed).
And once on 23:55.
Then you can differ on trigger in your script, when:
- timer: read the total counter value and story it into a variable
- device: calculate the self_kwh and update the counter ( with total counter+self_kwh)
See for example https://wiki.domoticz.com/DzVents:_next ... ined_rules
jslegers
Post by jslegers »
Script looks ok but have one small issue. (Sorry I am not a programmer).
The next day it starts with a negative value. So looks like it is not reset.
How can I fix this?
That is because you probably did not follow my advise to use the total counter just before midnight and add that to the daily self_kwh value you get from your device.
If you do not do that the counter will start at 0 and domoticz will interpret that as a negative value from the day before.....
jslegers
Post by jslegers »
I have setup some sensors. I will let it run for a week to see what happens. I let it run every day at 23:50. Via telegram I also get the values so the script runs. After a couple of days i will check if it works.
Hopefully it works.
jslegers
Post by jslegers »
Hi guys,
I am still testing. Still not getting the correct dummy device but still testing.
I will keep you updated.
John
jslegers
Post by jslegers »
I still have issues with storing the data. And I can't figure it out anymore.
Ok I have created the following development script.
        timer = {
            'at 23:50'
    logging = {
        marker = 'CounterReader'
    execute = function(domoticz, timer)
        local P1 = domoticz.devices(1)
        local GoodWe = domoticz.devices(50)
        if not P1 then
            domoticz.log('Device with IDX 1 not found!', domoticz.LOG_ERROR)
            return
        if not GoodWe then
            domoticz.log('Device with IDX 50 not found!', domoticz.LOG_ERROR)
            return
        local deliveryToday = P1.counterDeliveredToday
        local generatedToday = GoodWe.counterToday
        local resultToday = generatedToday - deliveryToday
        local dailyUsage = domoticz.devices(56)  -- your new dummy device IDX
        if not dailyUsage then
            domoticz.log('Dummy device IDX 56 not found!', domoticz.LOG_ERROR)
            return
        local dailyUsage2 = domoticz.devices(57)  -- your new dummy device IDX
        if not dailyUsage2 then
            domoticz.log('Dummy device IDX 57 not found!', domoticz.LOG_ERROR)
            return
        local dailyUsage3 = domoticz.devices(58)  -- your new dummy device IDX
        if not dailyUsage3 then
            domoticz.log('Dummy device IDX 58 not found!', domoticz.LOG_ERROR)
            return
       local dailyUsage4 = domoticz.devices(59)
        if not dailyUsage4 then
            domoticz.log('Dummy device IDX 59 not found!', domoticz.LOG_ERROR)
            return
-- resultToday is in kWh, store directly (no *1000 needed for Custom Sensor)
        dailyUsage4.updateCustomSensor(resultToday)
        dailyUsage.updateCounter(resultToday*1000)
        dailyUsage2.updateElectricity(0, resultToday*1000)
        dailyUsage3.updateCounter(resultToday*1000)
        domoticz.log('CounterDeliveredToday IDX 1: ' .. tostring(deliveryToday) .. ' kWh', domoticz.LOG_INFO)
        domoticz.log('CounterToday IDX 50: ' .. tostring(generatedToday) .. ' kWh', domoticz.LOG_INFO)
        domoticz.log('Result: ' .. tostring(resultToday) .. ' kWh', domoticz.LOG_INFO)
        domoticz.notify(
            'Daily Usage Update',
            'The daily calculation result is: ' .. tostring(resultToday),
            domoticz.PRIORITY_NORMAL,
            nil,
            {domoticz.NSS_TELEGRAM}
The script calculation is working fine. I only have an issue with storing the issue on a dummy device.
I have created the following dummy devices :
But none of the show the correct history :
Device 56
Device 59
These are the results that should be there :
5-6 : 6.232
4-6 : 3.746
3-6 : 5.779
2-6 : 5.28
I don't get what I am doing wrong. I just start the script at 23:50
Am I using the wrong dummy device?
Sorry I wanted to upload all the dummy's I had but was limit to 4 so In my next post there are the dummy switches.
jslegers
Post by jslegers »
Device 56
Device 57
Device 58
Device 59
jslegers
Post by jslegers »
Ok I have changed the script and will try a custom sensor again. Below is my cleaned up script.
        timer = {
            'at 23:50'
    logging = {
        if not P1 then
            return
        elseif not GoodWe then
            return
        elseif not dailyUsage then
            return
        local resultToday = math.max(0, (generatedToday - deliveryToday) * 1000)
        dailyUsage.updateCustomSensor(resultToday)
        domoticz.notify(
            nil,
I will keep you informed.
