Thermostat 6
- knasson
- Domoticz version: 2026-3
Thermostat 6
Presented in the teaser as a new thermostat integration in domoticz 2026-1 and i am interested in.
"Thermostat 6
is a new device type that combines a Setpoint and a Temp/Hum/Baro sensor into a single unit - mirroring how real thermostats work. Previously, users needed two separate devices for the target temperature and the actual sensor reading. Now both live together, with full EventSystem support (dzVents/Blockly/Lua/Python), notification thresholds for temperature, humidity, and barometer, and setpoint schedule support via MQTT-AD." I had a look to the plugins list integrated in domoticz and did'nt see this thermostat name, where could we find this thermostat ? has it a different name?
"Thermostat 6
- gizmocuz
Re: Thermostat 6
It is a device, not a plugin. Some MQTT devices support this, or you can manually add one on a dummy hardware and use it with dzVents scripting (or python scripts)
- knasson
Re: Thermostat 6
Thank you,
therefore but we have to write the script for managaing the thermostat itself.
Perhaps there is probably some ready to use script examples using these specific devices?
- Domoticz version: 2026.3
Re: Thermostat 6
It is just a combination of a Domoticz Thermostat/setpoint and a Temperature device. So in scripting there is nothing special.
The special thing is it lands on the temperature Tab and not in the Utility Tab like a normal thermostat device.
domcars0
- Domoticz version: 2026.2
Re: Thermostat 6
HI,
I'm trying to update the T° of a Thermostat6 device (Temperature/setPoint) from an ESPEasy rules but it looks like the update need also the setPoint ?
Without the setPoint in the sValue Domoticz return an error :
Error: Thermostat6: Invalid sValue - need at least temp;setpoint
Error: MQTT: Problem updating sensor (check idx, hardware enabled)
My Rule contain the line :
Publish domoticz/in,'{"idx":1004,"nvalue":0,"svalue":"[Eau_Chaude#Temperature]"}'
if I change it to :
Publish domoticz/in,'{"idx":1004,"nvalue":0,"svalue":"[Eau_Chaude#Temperature];74.5"}'
it works but of course I do not want to change my ESPEasy rule each time I want to change the setPoint.
Is it not possible to just update the T°?
My Dz version is : v2026.2 (build 18021)
if I change it to :
Re: Thermostat 6
It seems that `Thermostat6` requires both values (`temperature;setpoint`) with each update, based on the error message. It would be great if Domoticz could retain the current setpoint when only the temperature is updated. This might be worth suggesting as a feature request, unless there's an existing MQTT option that allows the current setpoint to be preserved. I'm curious if anyone has discovered a more straightforward workaround for this issue.
Re: Thermostat 6
The api update commands for this thermostat device are described here https://wiki.domoticz.com/Domoticz_API/ ... at_control
As it is a copy of an existing evohome thermostat the developer just followed that update set it seems.
Re: Thermostat 6
is the http API working for this device:
If this is working then MQTT should also work.
Edit: You want to only update the temperature.... Then you also need to set the setpoint....
/json.htm?type=command¶m=setsetpoint&idx=IDX&setpoint=SETPOINTEdit: You want to only update the temperature.... Then you also need to set the setpoint....
Gravityz
Re: Thermostat 6
i am using the thermostat6 device for a while now and it works like a charm.
indeed i do update both values because this is also the way when using MQTT.
when a device does not use nvalue we still need to send it with value 0
i use this(and no it is not redundant code)
local THERMOSTAAT = 'Thermostaat'
local thermostat = domoticz.devices(THERMOSTAAT)
Update setpoint(only 1 variable needed)
thermostat.updateSetPoint(actualSetpoint).silent()
update thermostat(temp and setpoint needed)
thermostat.updateThermostat(
temperatureDevice.temperature,
thermostatSetpoint
thermostatSetpoint
