Since some days, in beta, the graph for energy prices for day ahead, only shows for the next hour and not anymore to all data that is there (I assume the data is loaded for next 24 hrs). Same for solar power prediction (using a plugin I created).
IS this an update to the graph? Do we need to use different device type or settings on graph to see future data?
Change in future data in graphs
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
Version: xxxx
Platform: xxxx
Description:
JanJaap
- Domoticz version: Dev
JanJaap
Re: Change in future data in graphs
Solved in latest beta -> edit: not solved....
JanJaap
So it is not really solved. The data is somewhere present in the graph but it requires sideways scrolling. Which works with a gesture on a mobile device but not on a computer. Anything that can be done?
- gizmocuz
Solved in latest beta? And not solved?
There are many different types of energy devices in Domoticz.
Did you created a github issue? If yes, did you report it back in the issue it was not solved?
Did you add screenshots in the github issue? or somewhere here on the forum?
I have an idea why this happens. This is probably related to managed counter devices?
