Script python: Error executing script command .... returned: 256 Topic is solved
Pchatill
Domoticz version: v2026.2
Post by Pchatill »
Hi everydody.
I try to work with a python script find on:
But it doens't works
DE.Log("Python: Changed: " + DE.changed_device.Describe())
if DE.changed_device_name == "Test":
    if DE.Devices["Test_Target"].n_value_string == "On":
        DE.Command("Test_Target", "Off")
    if DE.Devices["Test_Target"].n_value_string == "Off":
        DE.Command("Test_Target", "On")
DE.Log("Python: Number of user_variables: " + str(len(DE.user_variables)))
# All user_variables are treated as strings, convert as necessary
for key, value in DE.user_variables.items():
    DE.Log("Python: User-variable '{0}' has value: {1}".format(key, value))
# Description of Device_object should go here...
If I run this script with Domoticz (Setup/More options/Events) then everything is OK
But if I want to run with the graphical interface (I mean Switch/Edit Device:script://essai1.py)
Then I have the error: Script python: Error: Error executing script command .... returned: 512
If I add the shebang !/usr/bin/env python3 th error became 256.
If I run the script in the terminal then I have:
File "/home/pchatill/domoticz/scripts/python/./essai1.py", line 3, in <module>
import DomoticzEvents as DE
ModuleNotFoundError: No module named 'DomoticzEvents'
I looked on the forum but I didn't find a solution.
Any idea?
Thanks for helping
Re: Script python: Error executing script command .... returned: 256
When running a python script as an action script on a device/switch it is not an eventscript and Domoticz events integration is not working.
The action scripts are normally used to control something outside Domoticz and no integration with Domoticz is supported.
If you want to control something inside Domoticz you need to use an eventscript as you did before.
Pchatill
Post by Pchatill »
That's clear!!
Thanks a lot for the answer waltervl!
