Domoticz build 17502: Password protected switches on dashboard not working anymore
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
BarryT
Domoticz version: 2024.3
Post by BarryT »
in latest version v2025.2 (build 17502) it is not possible to switch a protected switch/device on the dashboard anymore..
There is no popup asking for password, so we can not use protected switches at this moment.
I hope this is going to be fixed asap!
gizmocuz
Re: Domoticz build 17502: Password protected switches on dashboard not working anymore
Post by gizmocuz »
For what type of switch is this? I do get the password protection popup.
(Just tested with a normal dummy switch, and it is also working for setpoints)
Did you try pressing ctrl-shift-r as well? (forced browser cache reset), Should not be needed, but you can try..
And is this on the normal dashboard, mobile or the floorplan ?
gizmocuz
Post by gizmocuz »
Found something that could effect the mobile (dashboard) popup behaviour.
Please try beta 17506
BarryT
Post by BarryT »
It was in groups, i made a group with Off to turn off everything.
I have disabled the cache function in Domoticz, but its working again!
Thanks for the fast fix 👍🏾
