beta 17447 to 17452
Posted: Friday 20 March 2026 9:55
by Dave21w
Update from 17447 to 17452 Domoticz fails to restart, tried on 2 different beta installs, same on both. a sudo systemctl restart domoticz does start it though.
Re: beta 17447 to 17452
Posted: Friday 20 March 2026 10:06
Did you update over webgui? Did you try to run manually:
sudo ./updatebeta
What hardware/OS are you running as it could be related to
viewtopic.php?t=44457
Posted: Friday 20 March 2026 11:28
by Andreotti
Same here. 17452 does not start automatic. Manual restart does the trick.
Raspberry Pi 4 with Trixie13.4
Posted: Friday 20 March 2026 11:55
by Rik60
Maybe you have to wait a while, I have seen that when the counter reach 100, that when the counter could be at 130, the dashboard is back without a service restart
Posted: Friday 20 March 2026 12:25
by Dave21w
Update was done via the gui, have to wait until another update to see if it actually restarts then
Posted: Friday 20 March 2026 12:57
by Dave21w
Just updated to 17458 and now restarts OK
Posted: Friday 20 March 2026 13:08
by Andreotti
I waited long enough but I needed a manual restart on 17458 also.
The log says the service has started, but it looks like there's no connection to the database.
Posted: Friday 20 March 2026 13:42
by Rik60
Hmm, yesterday i did an update to 17437 without problems. Now the update again through the web ui, Domoticz didn't come online. Had to do a service restart. There is still something going on with the update procedure when using the web ui. After the service restart Domoticz was on 17459.
Posted: Friday 20 March 2026 14:04
by Andreotti
Same with 17459.
The log says the service has started.
But the files domoticz.db-shm and domoticz.db-wal are missing. After manual restart they are there again.
Posted: Saturday 21 March 2026 22:05
by gizmocuz
Andreotti wrote: Friday 20 March 2026 14:04
Same with 17459.
They suppose to be missing when the Domoticz service is shutdown properly. (you can google what these extensions mean)
try the following
sudo killall -9 domoticz
sudo service domoticz.sh start
This should get you up and running correctly, next try the web update
If it still does not work, just issue
cd domoticz
./updatebeta
Posted: Sunday 22 March 2026 10:55
by rene2716
Next update 17477 won't install either, no progress shown and keeps coming back
Posted: Monday 23 March 2026 13:21
by Dave21w
Update to 17484 via WebUI all good
Posted: Monday 23 March 2026 20:25
by Rik60
No issues anymore. Updating though the web ui was ok. Tested with Bookworm and Trixie. Running Beta 17492 now.
Posted: Tuesday 24 March 2026 10:23
by Rik60
Updating through the web ui failed. After some time: No internet connection...The update log file showed that the update was finished. Updating was from 17494 to 17497. A domoticz service start did not help, had to do a service restart.
Posted: Tuesday 24 March 2026 21:01
by gizmocuz
@Rik
Just wanting to point out that I (and others) with multiple installations do not experience this issue.
As you are already in discussion with us on Github, it is not needed to create a forum post.
(cross posting is not allowed, and causes us double the work)
