new json call
Posted: Friday 13 March 2026 21:06
i'm using evo home for many years changing setpoint using json calls from a lua script with a black box model to smart heat my rooms.
recently i added a new domoticz server with a newer version of domoticz (Version: 2025.2) and the json call to update the temperature setpoint is different
i used to use
/json.htm?type=setused&idx=<idx>&setpoint=<setpoint>&mode=<mode>&used=true
what has now changed according to the documentation to
/json.htm?type=command¶m=udevice&idx=IDX&nvalue=0&svalue=TEMP;SETPOINT
if i add ;PermanentOverride to the string, i do see the device updated in domoticz and data looks oke, but very shortly after it jumps back to the original setpoint
anybody using evo home with a recent domoticz build (Version: 2025.2 or higher) and got this working?
when i use the set temperature from the normal dashboard it does change the temperature setpoint correctly
i used to use
