Dzvents consumes high CPU
- Domoticz version: 2026.3
Re: New Dutch DzVents RIVM Stookalert
As a test you can just add the Domoticz logging demo script. It should do nothing until you switch the dummy test device. I wonder if that also consumes that high amount of CPU resources.
janpep
- Domoticz version: v2026.3
I think that EventSystemQueue processes all events, including those defined in Blockly.gbonny wrote: Monday 09 March 2026 20:27 One thing I noticed is after enabling this script Domoticz starts consuming an extra ~5-7% CPU usage.
I don't quite understand what the problem is. That the CPU doing something? And if the CPU does this four times a day, what is the problem?
In my case, it ranges from 1 to 10, but mostly between 2 and 5 and so varies greatly depending on what's running. Not surprising. I have several scripts with quite a few calculations.
If RIVM only updates the data four times a day, it does not seem very useful to run it more often. It always returns the next four time points.It seems that this script should only run 4 times a day..
My Dutch local 'Stookwijzer' script always calculates using the current and expected values and gives more time points.
Dz on Ubuntu VM on Proxmox behind FRITZ!Box.
EvoHome; MELCloud; P1 meter; Z-Stick GEN5; Z-Wave-js-ui; Sonoff USB-Dongle Plus-E; Zigbee2Mqtt; MQTT; Greenwave powernodes 1+6; Fibaro switch, plugs, smoke; FRITZ!DECT 200. Scripts listed in profile interests.
Re: Dzvents consumes high CPU
I splitted off the CPU issue from the RIVM topic as it is not related. I have the same Domoticz version and Ubuntu, not having this issue....
I am also not seeing this on latest beta.
Do you have a lot of devices?
janpep
Yes, thank you very much. I already had the feeling it was getting a bit off topic.waltervl wrote: Tuesday 10 March 2026 22:31 I splitted off the CPU issue from the RIVM topic as it is not related. I have the same Domoticz version and Ubuntu, not having this issue....
- gizmocuz
@gbonny, they is quite a few. And if you have scripts that could react on any device update, you will CPU usage
Upgrade to the beta and you should see already less CPU usage
- gizmocuz
@gbonny, yes once all changes in the beta are stable (they are quite stable but there is a big frontend patch that possibly needs more attention)
