Using domoticz version 2024.7 on windows 11 having rebuilt the database following corruption.
The domoticz app is working fine no errors in the log.
When I try to do a backup I get an empty file created called 'backupdatabase.php'. Backup button was working normally before.
Anyone got any ideas ?
Unable to backup database from UI
peterchef
- Domoticz version: 2024.7
Windows, Domoticz
Aeotec Z-Stick Gen5, Aeotec Multisensor 6, Horstmann HRT4-ZW Thermostat Transmitter, Horstmann ASR-ZW Thermostat Receiver
Zipato Mini Keypad RFID, Everspring AN157 Plug
- Domoticz version: 2026.3
Re: Unable to backup database from UI
Seems to be an issue with your browser settings. Perhaps try another browser?
Check antivirus scanner?
peterchef
I tried another browser with the same result. I also tried the browser on a different domoticz installation and that backed up OK.
It just seems to be a problem on the machine where I had to rebuild the database using sqlite3.
I don't know where the backup database script exists.
Windows, Domoticz
That backup script is a symbolic link to an hardcoded sqlite3 function in domoticz.
So it must something wrong with either your installation or your browser. Did it work with a previous installation?
peterchef
I think it is an installation problem. It used to work. When the database became malformed I had to rebuild it.
I used sqlite3 using .dump to create an sql file of the malformed database. Then I recreated the database from the sql file. Since then the backup will not work. I can see that the backup button is set to
http://192.168.1.143:8080/backupdatabase.php
But it just creates the file backupdatabase.php instead of the .db file. No errors in the log file.
Windows, Domoticz
