Tuya plugin PYTUYA no longer working
Posted: Tuesday 24 February 2026 15:20
I am using for years "pytuya" pluging to get access to TUYA device on local network on my Raspberry PI 3 running Domoticz 2022.1 version under "Buster" OS
I have now decided to install the last version of Domoticz 2025.2 on a new Raspberry PI5 running "Trixie"
Domoticz is running fine but I am no longer able to install the plugin "pytuya" on this OS. I have uses VENV on this install but even with this configuration I am not able to install it
I have the following message
As far as I can understand it cannot found module "Crypo" and "pyaes", but if list the install modules they are present
On domotcz startup (/etc/init.d/domoticz.sh) I have added the VENV environment
Any advice for solving this issue ?
Patrick
(Domoticz_Python_Environment) admin@pi5max:~/domoticz/plugins $ pip install pytuya
Collecting pytuya
Using cached pytuya-7.0.6.zip (11 kB)
Installing build dependencies ... done
Getting requirements to build wheel ... error
error: subprocess-exited-with-error
× Getting requirements to build wheel did not run successfully.
│ exit code: 1
╰─> [33 lines of output]
File "/tmp/pip-install-ci6a3pgy/pytuya_345f75310712492fbb5ef8fec14e281a/pytuya/__init__.py", line 24, in <module>
import Crypto
[ ModuleNotFoundError: No module named 'Crypto'
During handling of the above exception, another exception occurred:
File "/home/admin/Domoticz_Python_Environment/lib/python3.13/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 389, in <module>
main()
File "/home/admin/Domoticz_Python_Environment/lib/python3.13/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 373, in main
json_out["return_val"] = hook(**hook_input["kwargs"])
File "/home/admin/Domoticz_Python_Environment/lib/python3.13/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 143, in get_requires_for_build_wheel
return hook(config_settings)
File "/tmp/pip-build-env-2xre7gbv/overlay/lib/python3.13/site-packages/setuptools/build_meta.py", line 333, in get_requires_for_build_wheel
return self._get_build_requires(config_settings, requirements=[])
File "/tmp/pip-build-env-2xre7gbv/overlay/lib/python3.13/site-packages/setuptools/build_meta.py", line 301, in _get_build_requires
self.run_setup()
File "/tmp/pip-build-env-2xre7gbv/overlay/lib/python3.13/site-packages/setuptools/build_meta.py", line 520, in run_setup
super().run_setup(setup_script=setup_script)
File "/tmp/pip-build-env-2xre7gbv/overlay/lib/python3.13/site-packages/setuptools/build_meta.py", line 317, in run_setup
exec(code, locals())
File "<string>", line 9, in <module>
File "/tmp/pip-install-ci6a3pgy/pytuya_345f75310712492fbb5ef8fec14e281a/pytuya/__init__.py", line 28, in <module>
import pyaes # https://github.com/ricmoo/pyaes
ModuleNotFoundError: No module named 'pyaes'
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed to build 'pytuya' when getting requirements to build wheel
(Domoticz_Python_Environment) admin@pi5max:~/domoticz/plugins $ pip list
Package Version
certifi 2026.1.4
cffi 2.0.0
charset-normalizer 3.4.4
colorama 0.4.6
crypto 1.4.1
cryptography 46.0.5
distlib 0.4.0
filelock 3.24.0
idna 3.11
Naked 0.1.32
packaging 26.0
pip 26.0.1
pipenv 2026.0.3
platformdirs 4.9.1
pyaes 1.6.1
pycparser 3.0
pycrypto 2.6.1
pycryptodome 3.23.0
PyYAML 6.0.3
requests 2.32.5
setuptools 82.0.0
shellescape 3.8.1
tinytuya 1.17.4
tuyapower 0.2.0
urllib3 2.6.3
virtualenv 20.36.1
wheel 0.46.3
export PYTHONPATH=/home/admin/Domoticz_Python_Environment:$PYTONPATH
Patrick
