Domoticz access blocked
Posted: Tuesday 24 February 2026 9:46
by miguell
Hi, I am using Domoticz on a Raspberry Pi. After an update, a login screen appears upon startup. It asks for a username and password. Then a message appears stating they are incorrect, and after three attempts, a screen appears with the message: "congratulations …….the end of the internet". The strange thing is that Domoticz is otherwise working fine; the lights are on. But Domoticz is inaccessible.
Software and hardware used:
Domoticz running on a Raspberry Pi.
What I have already found or tried:
I connect to the Raspberry Pi via SSH. I tried to repair Domoticz or completely reinstall it. Nothing helped.
Does anyone have a solution to my problem?
Re: Domoticz access blocked
Posted: Tuesday 24 February 2026 9:55
by waltervl
On a fresh install domoticz username/password is admin/domoticz
Else check https://wiki.domoticz.com/Lost_Username_Password to reset the default password.
Also make sure you have an admin as a user: https://wiki.domoticz.com/User_Management when you are updating from an old install.
Posted: Tuesday 24 February 2026 10:06
by miguell
Thanks, I'll try to do that.
Posted: Tuesday 24 February 2026 14:41
by jannl
And you may add the local (v)lan to the security settings, to prevent a user/passwd from being asked when accessing locally (or via a vpn)
