3 fase Amp meter shows just one zero iso 0,0,0
Forum rules
Version: xxxx
Platform: xxxx
Plugin/Hardware: xxxx
Description:
BartSr
Domoticz version: V2024.7
Post by BartSr »
Hi I am using a 3 fase Amp device Type " Current, CM113,Electrisave ".
It shows as expected the Amp values but if no current in all fases it just shows only one time zero. Is this as intended or is it a bug.
-Bart
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Esp8266 / 32 espeasy
Zigbee2MQTT
Re: 3 fase Amp meter shows just one zero iso 0,0,0
Does it show then a single 0 value only on display or also in the device list (menu setup - devices)?
BartSr
Post by BartSr »
Both device list as well as dashboard and utility page are showing '0.0' identical
Raspberry pi 3b
Arduino
KAKU
RfxCom
Zwave2MQTT
OTGW
Tasmota
Zigbee2MQTT
