Notifications, source?
Posted: Tuesday 17 February 2026 19:41
by Patricen
Hello, i'm receiving notifications through Telegram but i'm unable to find where they are coming from.
The history: I do have trvs that were "eating" batteries. I then decided to send a notification with a specific message as soon as the temperature was not reported after a certain time.
I fixed the issue for the trvs, removed the notification but i'm still receiving it.
Any clue?
Re: Notifications, source?
Posted: Tuesday 17 February 2026 22:01
by willemd
Configuration for telegram is in the settings.
notifications can then be sent from many places, for example
1) from a device directly
2) from a plugin
3) from dzvents
4) using a json command
Posted: Wednesday 18 February 2026 11:42
by Patricen
Ok thanks. Due to the notification text that is sent, it is something sent directly from a device as it was configured as follows
Image.
The issue is that I did delete the notifications from devices but they are still pushed through Telegram.
I checked Domoticz.db database integrity that is ok and tried to find the specific notification message within the database without success.
It looks like there is still an issue, can somebody help about that?
Posted: Wednesday 18 February 2026 17:49
by willemd
Your two screenprints still show an active notification. Did you select the notifcation and then press delete? Or did you press clear in the bottom right corner?
Posted: Thursday 26 February 2026 15:51
by Patricen
Yes of course, I did add this notification to check if it is possible to see the specific text within domoticz.db tables but without success, as I'm receiving old messages set to other sensors but that have been deleted.
