Domoticz crash after database restore
Posted: Monday 16 February 2026 10:11
by Rik60
After a database restore Domoticz doesn't come online, no devices found or no communication...
Did a service restart, after that domoticz was running normal. Tried this with a database backup and restore (no database changes) and after a powercycle of the Rpi3B+. Seen this also on earlier versions of the beta (2025.2 17057, 2025.2 17099 and 2502.2 17189).
Attached is a crash log after a database restore.
Re: Domoticz crash after database restore
Posted: Tuesday 17 February 2026 9:39
by Kedi
From the crashlog I can only see that you have a problem with libpython3.13.so and the Somfy plugin.
Posted: Tuesday 17 February 2026 11:55
by Rik60
Thanks.
Removed Somfy to test, problem still exist. I am on Trixie and Domoticz beta 2025.2 17198, going to test with an older os (Bullseye, Bookworm) and older Domoticz.
Am i the only one with this problem?
Posted: Tuesday 17 February 2026 16:29
by Rik60
Did some tests with another os (Bookworm) and Domoticz versions.
Trixie + Stable 2025.2 restore database Domoticz crash, restart domoticz service
Bookworm + Stable 2025.2 restore database Domoticz online Ok
Bookworm + beta 2025.2 17163 restore database Domoticz online Ok
Bookworm + beta 2025.2 17163 restore database from Trixie 2025.2 17163 Domoticz online Ok
Bookworm has Python 3.11
So, there is a problem with Trixie with python version 3.13?
Posted: Wednesday 18 February 2026 9:15
by Rik60
Saw that Gizmocus is working on it....#6577
Edit: Updated to last beta 17163, same problem. On trixie domoticz is crashing after database restore, on Bookworm not
Posted: Friday 20 February 2026 21:36
by Rik60
Gizmocuz has solved the issue. No issues anymore
