Domoticz doesn't start after update beta
Posted: Sunday 15 February 2026 20:21
by Rik60
After a update from beta 17099 to 17189 Domoticz did not restart. Did the update throuh the settingsscreen. Counter counted until 100, then the message update failed, no internet connection....
After a domoticz service restart was domoticz running normaal on the downloaded beta 17189. I thought this problem was solved? Attached the update.log and domoticz crash log
Re: Domoticz doesn't start after update beta
Posted: Monday 16 February 2026 16:07
As mentioned in the history text you probably have to update twice due to libmosquitto library addition when you are on an older updatebeta script.
So next time the web update will/should run successful.
Edit: I now see the log and see the error:
gdb: warning: Couldn't determine a path for the index cache directory.
No idea what is happening here....
Posted: Wednesday 18 February 2026 22:01
by gizmocuz
Did you run updatebeta twice, and did that solve the issue?
Posted: Thursday 19 February 2026 10:44
by Rik60
When i was building a test sd card and did some installations, release and beta, from the setting screen, there where no issues. I am not shure because did a lot of testing yesterday. Have to do that again.
Posted: Thursday 19 February 2026 16:41
by Rik60
Created a new sd card with Trixie 64 bit lite. Installed Domoticz 2025.2 stable. Through the settingsscreen (check for updates) installed beta 2025.2 17175. No problems, during the countdown the dashboard came back normaal. No issues.
Posted: Friday 20 February 2026 21:34
by Rik60
Updated to the last beta 2025.2 17204. No issues.
