Prowl in dzVents not working
Posted: Thursday 12 February 2026 19:28
by Gingerpale
Since latest few beta versions, Prowl is not working anymore when fired from dzVents.
E.g.
domoticz.notify('Prowl', 'Test Dz', domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_PROWL)
It still works when testing it in "Settings - Notifications - Prowl" and it also works when fired from Blockly script.
Any known issue here?
Re: Prowl in dzVents not working
Posted: Thursday 12 February 2026 19:45
What if you use something simple and have the prowl messaging globally active. Do you get the message on all active notification systems including Prowl?
domoticz.notify('Prowl', 'Test Dz')
Posted: Thursday 12 February 2026 21:35
by Gingerpale
I only have Prowl active, but testing with
doesn't work either.
And if I do the same in Blockly: select subsystem "all", it does work.
And it always worked before. I use it in many dzVents scripts for years. So it seems that something has changed. But what?
Posted: Thursday 12 February 2026 21:48
In another issue someone did accidentally set domoticz.NSS_PROWL to nil in his script.
You have not done that?
Do you remember on what version it still worked in beta?
Posted: Thursday 12 February 2026 22:15
by Gingerpale
I usually install new beta's within a day or so after they have been released. And I see from my logs that it still worked at Feb 6th. After that it stopped working. So is it about 3 beta's ago?
I created a test script for this issue and I literally use this line in my test script (and similar in all my other scripts)
on =
devices =
'Test ToggleSW',
logging =
level = domoticz.LOG_INFO,
marker = 'Prowl Test',
domoticz.log('Script fired by device: '.. item.name .. ': ' .. item.state, domoticz.LOG_INFO)
if domoticz.devices(item.name).state == 'On' then
-- domoticz.notify('Prowl', 'Test Dz', domoticz.PRIORITY_NORMAL,nil,nil,domoticz.NSS_PROWL) -- original notify message
domoticz.notify('Prowl', 'Test Dz') -- Waltervl test suggestion
domoticz.log(item.name .. ' triggered', domoticz.LOG_INFO)
-- do nothing
end -- execute
Posted: Thursday 12 February 2026 23:21
It seems notification from dzvents is not working at all on recent beta (17099, I still have to update to latest), so looks like a bug. I will make a github issue if needed.
If you do
It should also trigger a browser notification on top right corner. In stable it does, in beta is does not. Also Android Google Firebase notifications are not working from dzvents.
Posted: Thursday 12 February 2026 23:49
Posted: Friday 13 February 2026 22:19
Fixed in current beta.
Posted: Saturday 14 February 2026 10:06
by Gingerpale
I've installed latest Beta and I can confirm it's working again!
