Airplane tracker plugin
Tukker
Domoticz version: 2023.2
Post by Tukker »
I designed a plugin for Airplane Tracking based on the work of @janpep 'Script for Airplanes.live API'.
Installation is quite simple.
1) mkdir ~/domoticz/plugins/AirPlaneTracker
2) Copy the code to ~/domoticz/plugins/AirPlaneTracker/plugin.py
3) do a 'sudo systemctl restart domoticz'
4) Goto hardware and select the plugin 'Airplane Tracker', give it a name (adapt settings) and click on 'Add'
5) Goto the 'Utility'tab, find the Airplanes - Counter, click edit and change the counter Type from Energy to Custom
5) Off you go
The names of the sensors are made up of 2 parts.
- The name you give to the plugin @install
- the name of the sensor
Example: I gave the plugin the name Vliegtuigen so the name of the Tracker sensor is Vliegtuigen - Tracker
The sensors are:
Tracker - displays the planes flying over your head
Counter - counts the planes flying over your head
Types - Counts the types of planes flying over your head
Screenshot 2026-02-09 150946.png (20.64 KiB) Viewed 2448 times
When you click on the CallSign of an plane like KLM1844 or RYR9HN or BAW979 in de Tracker sensor, a new Airplanes.live tab opens in your browser and shows the plane on the map.
airplane - types.png (18.25 KiB) Viewed 2416 times
This is a one day score within 9 miles from my house.
# Airplane Tracker Plugin for Domoticz
# Author: Hein
<plugin key="AirplaneTracker" name="Airplane Tracker" author="Hein" version="2.28.1">
    <description>
        <h2>Airplane Tracker</h2><br/>
        <p>Monitor live air traffic around your location using the airplanes.live API.</p>
        <br/>
        <h3>Features</h3>
        <ul>
            <li><b>Tracker</b>: Shows the last 3 aircraft detected with details (altitude, speed, direction)</li>
            <li><b>Counter</b>: Cumulative count of all aircraft seen (resets daily by Domoticz)</li>
            <li><b>Types</b>: Daily summary of aircraft types detected</li>
        </ul>
        <br/>
        <h3>Configuration</h3>
        <ul>
            <li><b>Radius</b>: Detection radius in miles around your Domoticz location</li>
            <li><b>API Interval</b>: Time between API calls in seconds (default: 60).</li>
            <li><b>Log Unknown Types</b>: Logs unclassified types to ~/unknown_aircraft_types.log.</li>
            <li><b>Log Level</b>: Controls logging verbosity.</li>
            <li><b>Important - Counter Device</b>: After creation, go to <b>Devices</b>, click <b>Edit</b> on the Counter, and change <b>Type</b> to <b>Custom</b>.</li>
        </ul>
    </description>
    <params>
        <param field="Mode1" label="Radius (Miles)" width="75px" required="true" default="9"/>
        <param field="Mode2" label="API Call Interval (Seconds)" width="75px" required="true" default="60"/>
        <param field="Mode3" label="Log Unknown Types" width="75px" required="true" default="False">
            <options>
                <option label="No" value="False" default="true"/>
                <option label="Yes" value="True"/>
            </options>
        </param>
        <param field="Mode6" label="Log Level" width="150px" required="true" default="Error">
            <options>
                <option label="Error" value="Error" default="true"/>
                <option label="Status" value="Status"/>
                <option label="Info" value="Info"/>
            </options>
        </param>
    </params>
</plugin>
import Domoticz
import urllib.request, json, socket, time, math, os
from datetime import datetime
class BasePlugin:
    def __init__(self):
        self.last_seen_ts = {}
        self.tracker_buffer = {}
        self.type_counts = {}
        self.logged_unknowns = set()
        self.today = datetime.now().strftime('%Y-%m-%d')
        self.total_count = 0
        self.home_dir = os.path.expanduser("~")
        self.last_api_call = 0
    def should_log(self, level):
        log_level = Parameters.get("Mode6", "Error")
        if log_level == "Info": return True
        elif log_level == "Status": return level in ["Status", "Error"]
        else: return level == "Error"
    def classify_aircraft(self, t, desc):
        t = t.upper() if t else ""
        desc = desc.upper() if desc else ""
        # 1. Helicopters (Priority)
        if "HELICOPTER" in desc or "ROTORCRAFT" in desc or t in ["EC35", "EC45", "H135", "H145", "AS32", "EH10", "NH90", "CH47"]:
            return ("Helicopters", "helicopter")
        # 2. Special / Military / Large Transport
        if "RIVET" in desc or t == "R135":
            return ("Boeing RC-135 (Radar)", "known")
        if "AWACS" in desc or t == "E3TF":
            return ("Boeing E-3 AWACS", "known")
        if "GLOBEMASTER" in desc or t == "C17":
            return ("Boeing C-17 Globemaster", "known")
        if "ATLAS" in desc or t == "A400":
            return ("Airbus A400M Atlas", "known")
        if "HERCULES" in desc or t == "C130":
            return ("Lockheed C-130 Hercules", "known")
        if "STRATOTANKER" in desc or t == "K35R":
            return ("Boeing KC-135 Tanker", "known")
        # Specifiek voor A330 tankers (Voyager/MRTT) op basis van omschrijving
        if "VOYAGER" in desc or "MRTT" in desc:
            return ("Airbus A330 Tanker/Transport", "known")
        if "BELUGA" in desc or t in {"A3ST", "A337"}:
            return ("Airbus Beluga", "known")
        # 3. Airbus Families
        if t.startswith("A38") or "380" in desc:
            return ("Airbus A380", "known")
        if t.startswith("A35") or "350" in desc:
            return ("Airbus A350", "known")
        if t.startswith("A34") or "340" in desc:
            return ("Airbus A340", "known")
        # Algemene A330 check (vangt nu ook A332 op die niet Voyager is)
        if t.startswith("A33") or "330" in desc:
            return ("Airbus A330", "known")
        if (t.startswith("A31") or t.startswith("A32") or t.startswith("A2") or
            "A32" in desc or "A-32" in desc):
            return ("Airbus A320-family", "known")
        if t.startswith("BCS") or "A220" in desc:
            return ("Airbus A220", "known")
        # 4. Boeing Families
        if t.startswith("B73") or t.startswith("B3") or "737" in desc:
            return ("Boeing 737", "known")
        if t.startswith("B74") or "747" in desc:
            return ("Boeing 747", "known")
        if t.startswith("B77") or "777" in desc:
            return ("Boeing 777", "known")
        if t.startswith("B78") or "787" in desc:
            return ("Boeing 787", "known")
        if t.startswith("B75") or "757" in desc:
            return ("Boeing 757", "known")
        if t.startswith("B76") or "767" in desc:
            return ("Boeing 767", "known")
        # 5. Commercial Regional
        if (t.startswith("E17") or t.startswith("E19") or t.startswith("E2") or
            "E-JET" in desc or "E170" in desc or "E190" in desc):
            return ("Embraer E-Jet Family", "known")
        if t.startswith("DH8") or "DASH 8" in desc or "Q400" in desc:
            return ("Dash 8 / Q400", "known")
        if t.startswith("AT") or "ATR" in desc:
            return ("ATR 42/72", "known")
        if t.startswith("RJ") or t.startswith("B46") or "AVRO" in desc or "BAE 146" in desc:
            return ("Avro RJ / BAe 146", "known")
        if "FOKKER" in desc or t in ["F70", "F100"]:
            return ("Fokker 70/100", "known")
        # 6. Business & Recreational
        if (t in ["E135", "E140", "E145", "ER3", "ER4", "ERJ"] or "ERJ-1" in desc or "ERJ 1" in desc):
            return ("Business & Recreational", "small")
        small_codes = {
            "C25A", "C25B", "C25C", "C525", "C550", "C560", "C680",
            "C510", "C500", "C501", "C551", "GLF4", "GLF5", "GLF6", "G280", "GALX",
            "FA50", "FA7X", "FA20", "FA2K", "FA10", "LJ35", "LJ45", "LJ60",
            "BE20", "BE30", "BE40", "BE9L", "BE10", "PC12", "PC6", "PC24",
            "CL30", "CL35", "CL60", "GL5T", "H25B", "H25C", "HA4T", "SW4",
            "P28A", "P28R", "P28T", "PA46", "C172", "C182", "C208", "SR20", "SR22"
        small_keywords = ["CITATION", "GULFSTREAM", "FALCON", "LEARJET", "HAWKER",
                         "CHALLENGER", "PHENOM", "LEGACY", "BEECHCRAFT", "PILATUS",
                         "CESSNA", "PIPER", "CIRRUS", "METRO", "KINGAIR"]
        if t in small_codes or any(k in desc for k in small_keywords):
        # 7. Other Commercial / Classics
        if "MD11" in desc or t == "MD11":
            return ("McDonnell Douglas MD-11", "known")
        if "MD8" in desc or t.startswith("MD8"):
            return ("McDonnell Douglas MD-80", "known")
        return ("Other", "other")
    def log_unknown_type(self, hex_id, t, desc, reg):
        if Parameters.get("Mode3", "False") != "True": return
        log_key = f"{t}|{desc}"
        if log_key in self.logged_unknowns: return
        self.logged_unknowns.add(log_key)
        log_file = os.path.join(self.home_dir, "unknown_aircraft_types.log")
        timestamp = datetime.now().strftime('%Y-%m-%d %H:%M:%S')
        log_entry = f"{timestamp} | hex={hex_id} | t={t} | desc={desc} | r={reg}\n"
        try:
            with open(log_file, 'a') as f: f.write(log_entry)
        except: pass
    def get_cardinal_dir(self, angle):
        directions = ["N", "NNE", "NE", "ENE", "E", "ESE", "SE", "SSE",
                     "S", "SSW", "SW", "WSW", "W", "WNW", "NW", "NNW"]
        return directions[int((angle + 11.25) / 22.5) % 16]
    def calculate_distance(self, lat1, lon1, lat2, lon2):
        R = 6371
        dLat, dLon = math.radians(lat2 - lat1), math.radians(lon2 - lon1)
        a = math.sin(dLat/2)**2 + math.cos(math.radians(lat1)) * math.cos(math.radians(lat2)) * math.sin(dLon/2)**2
        return R * 2 * math.atan2(math.sqrt(a), math.sqrt(1-a))
    def onStart(self):
        if 1 not in Devices: Domoticz.Device(Name="Tracker", Unit=1, TypeName="Text", Used=1).Create()
        if 2 not in Devices: Domoticz.Device(Name="Counter", Unit=2, Type=113, Subtype=0, Used=1).Create()
        else:
            try:
                if Devices[2].sValue: self.total_count = int(Devices[2].sValue.split(';')[0])
            except: self.total_count = 0
        if 3 not in Devices: Domoticz.Device(Name="Types", Unit=3, TypeName="Text", Used=1).Create()
        Domoticz.Log("Airplane Tracker started.")
    def onHeartbeat(self):
        try:
            if "Location" not in Settings: return
            loc = Settings["Location"].split(";")
            my_lat, my_lon = float(loc[0]), float(loc[1])
            now_ts, now_dt = time.time(), datetime.now()
            if now_dt.strftime('%Y-%m-%d') != self.today:
                self.today = now_dt.strftime('%Y-%m-%d')
                self.last_seen_ts.clear(); self.tracker_buffer.clear(); self.type_counts.clear()
            api_interval = int(Parameters.get("Mode2", "60"))
            if (now_ts - self.last_api_call) < api_interval:
                self._update_displays(now_ts, now_dt, False); return
            self.last_api_call = now_ts
            url = f"https://api.airplanes.live/v2/point/{my_lat}/{my_lon}/{Parameters['Mode1']}"
            req = urllib.request.Request(url, headers={'User-Agent': 'Mozilla/5.0'})
            new_reg_found = False
            try:
                with urllib.request.urlopen(req, timeout=10) as r:
                    ac_data = json.loads(r.read().decode()).get('ac', [])
                    for p in ac_data:
                        hex_id = p.get('hex', '0').upper()
                        if hex_id == '0': continue
                        flight = (p.get('flight') or hex_id).strip()
                        t, desc, reg = p.get('t', ''), p.get('desc', 'Unknown'), p.get('r', '')
                        if hex_id not in self.last_seen_ts or (now_ts - self.last_seen_ts[hex_id]) > 300:
                            self.total_count += 1; new_reg_found = True
                            t_disp, cat = self.classify_aircraft(t, desc)
                            self.type_counts[t_disp] = self.type_counts.get(t_disp, 0) + 1
                            if cat == "other": self.log_unknown_type(hex_id, t, desc, reg)
                        self.last_seen_ts[hex_id] = now_ts
                        t_disp, _ = self.classify_aircraft(t, desc)
                        alt = round((p.get('alt_geom') or p.get('alt_baro', 0)) * 0.3048)
                        gs = round(p.get('gs', 0) * 1.852)
                        v_rate = p.get('baro_rate', 0)
                        v_str = f" (↑ {round(v_rate * 0.3048)} m/min)" if v_rate > 128 else (f" (↓ {round(abs(v_rate) * 0.3048)} m/min)" if v_rate < -128 else "")
                        dist = self.calculate_distance(my_lat, my_lon, p.get('lat', 0), p.get('lon', 0))
                        link = f"<a href='https://globe.airplanes.live/?icao={hex_id}' target='_blank' style='color:inherit;text-decoration:none;'>{flight}</a>"
                        line1 = f"{now_dt.strftime('%H:%M')} {link} - {t_disp} ({reg})"
                        line2 = f"{alt}m{v_str}, {gs}km/h, {dist:.1f}km {self.get_cardinal_dir(p.get('track', 0))}"
                        self.tracker_buffer[hex_id] = (line1 + "<br>" + line2 + "<br>", now_ts)
            except Exception as e:
                if self.should_log("Error"): Domoticz.Error(f"API Error: {e}")
            self._update_displays(now_ts, now_dt, new_reg_found)
            if self.should_log("Error"): Domoticz.Error(f"Heartbeat Error: {e}")
    def _update_displays(self, now_ts, now_dt, new_reg_found):
        expired = [k for k, v in self.tracker_buffer.items() if (now_ts - v[1]) > 1800]
        for k in expired: del self.tracker_buffer[k]
        if 1 in Devices:
            sorted_p = sorted(self.tracker_buffer.values(), key=lambda x: x[1], reverse=True)
            Devices[1].Update(nValue=0, sValue="<br>".join([p[0] for p in sorted_p[:3]]) if sorted_p else now_dt.strftime('%H:%M') + " No traffic")
        if 2 in Devices and new_reg_found: Devices[2].Update(nValue=0, sValue=str(self.total_count))
        if 3 in Devices and self.type_counts:
            sorted_t = sorted(self.type_counts.items(), key=lambda x: (x[0] == "Other", -x[1], x[0]))
            Devices[3].Update(nValue=0, sValue="<br>".join([f"{n}: {c}" for n, c in sorted_t]))
_plugin = BasePlugin()
def onStart(): _plugin.onStart()
def onHeartbeat(): _plugin.onHeartbeat()
Bugs bug me.
Tukker
Re: Airplane tracker plugin
Post by Tukker »
BTW
I'm using a lot of text sensors thus condensing information to avoid pages full of counters and switches.
That is not very smart because it clogs up the database with text.
So I use a Bash script to clean up the domoticz database once a week.
Bugs bug me.
RonkA
Domoticz version: 2025.1
Post by RonkA »
F.Y.I.
I also use many text-devices but i clear the log immediately after writing the new text into it using this at the end of my scripts:
-->-->--> Clear the log of the textdevice, put in the right idx of the textdevice!!
     	  domoticz.openURL('http://127.17.0.2:80/json.htm?type=command&param=clearlightlog&idx=337')
SolarEdge ModbusTCP - Kaku - Synology NAS - Watermeter - ESPEasy - DS18b20
Work in progress = Life in general..
Tukker
Post by Tukker »
RonkA wrote: Sunday 15 February 2026 11:54 F.Y.I.
Smart!
Bugs bug me.
